Derek1948 1
I have my heating panel set up to control the timing of 4 zones. Each zone has a SRT321 themostat connected to Fibaro relays which switch electric heaters. The timing from the heating panel works perfectly. Also, if I need to deviate from that pattern I can successfully do that through the heating panel manual setup (e.g. change the setting to 180 for 3 hours.
I can also physically change the thermostat to alter the set temperature for a chosen number of hours. All fine.
However, if I change the temperature up on the HCL interface, although the message is successfully sent to the thermostats, the relay switches on for only a brief period (seconds) then reverts to off.
This is becomes a real problem if I want to change the temperature 'at a distance', e.g. through the android app.
What do you think is happening?
