Fibaro Motion Sensor - unable to rename or allocate to room
Hi
I recently acquired the HC2 and am still finding my way around it. I have encountered an issue which I cannot find a solution for. Not sure if I did something wrong. I have added a Fibaro Motion Sensor. The adding part appears to go fine with all the components showing up under unallocated. (i.e the motionsensor, temperature etc). However they just have port nrs as names and when I select them, I am unable to rename or allocate to a room (both on general or advanced tabs.). The rooms drop down is empty and if I only type a new name and save, the screen just does the spinning circle and hangs. The sensor otherwise appears to work fine, returning temperature etc.
Would appreciate any suggestion on where it might be going wrong.
Regards
Hi @Highlander!
Have you tried to wake up the device after you click save in the web browser interface?
    Hi Srodka, Once I managed to get the Home Center upgraded to latest firmware, this issue resolved itself. Thanks
    Thanks for the update @Highlander!
