eureka 9
Just installed my Fibaro Heat Controller with Sensor. My homecenter 2 is picking up both the sensor and the heat controller (also connection between radiator and sensor was executed), so far so good. However, if I look at the temperature that the seperate sensor is providing. It says it's 0 degrees celsius. I've been waiting for a while now and also did a soft reset but it's still at 0 degrees.
What can be going wrong? or is this a known bug?
also: is there a known way to fix the sensor to the wall? I want it to be at 1.50meters to get correct temperature. But if i would fix it using tape I cannot get to the battery anymore. Probably i'm missing something because i can't imagine that they make a seperate sensor without having a way to fix it to something... right?
Edited by eurekaTop Posters For This Question
15
13
9
5
Jan 19
10
Dec 15
7
Jan 21
7
Dec 19
4
petergebruers 15 posts
samuelAN 13 posts
eureka 9 posts
Morgano 5 posts
Jan 19 2018
Dec 15 2017
Jan 21 2018
Dec 19 2017
eureka
@petergebruers I got an update from fibaro: Additional temperature sensor is communicating with The Heat Controller every 10minutes, and The Heat Controller sends those informatio
eureka
@I.Srodka any news on the firmware update? It's kinda hot in here...
65 answers to this question
