Guest jerome31750
Dear all,
Does somebody know the meaning of the blinking led of FGK-101 ?
I do nor read something clear on the doc.
It is because i got an issue on one of the three I got and I did not find an idea of what goes wrong.
When I set the battery it starts blinkink with short off for 1-2 seconds then stays off.
When I set or remove the magnet it blinks three times very fast.  When I press TMP for interrogation there is no light !
When i try a reset I got a solid ligh for 2 s but not the reset confirmation.  I the magnet is not present then it seems that the led is half-lighted for 1 s before fast blink.
A normal FGK behaviour is
A TMP press set in wake-up mode with slow blinking led for 5 seconds
Three TMP press set the module in association or de-association mode for 5 seconds (fast leds blinking).
Setting the battery with magnet and TMP pressed starts reset mode, removing magnets within the led is solid ligh (2 seconds) starts the reset, then remove battery at next power on rest is confirmed by double blink.
slowly blinking led means correct inclusion
fast blinking led means inclusion error
Hoping someone could help
