Home Cetner doesn't boot
Hello,We very much hope to get your help
I have two HC2, I call A and B. A can not boot,B can work normally, I want to keep A inside the data .
1
we try to enter the recovery mode, but it shows this, I do not know what that means
[A bootable device has not been detected.
Please refer to the Product Guide at
2
We also try to "VGA" to connect the monitor and HC, but do not know what to do after boot
3
Can I transfer disk A to B HC?A data is present inside this disk, right?
We tried a variety of combinations, but still can not read the disk A data on the B HC
Edited by Gee
4 answers to this question
Hi Gee,
1. Try to add your pictures again.
2. Check if you can boot your HC2 without mounted recovery stick.
Edited by RH_Dreambox
Hello @Gee!
I've seen that you wrote to our support as well.
Please wait patiently as they will investigate your issue.
@RH_Dreambox, I've checked that he had submitted those pictures in an original mail to our Support.
If the solution provided by the support won't satisfy you, please write here back ; )
    1 hour ago, RH_Dreambox said:
    Hi Gee,
    Thk,not ,it can not boot
    Hello Friends.
    I am dealing with the same problem. My HC does not boot and I see the same message:
    I could not find my motherboard at Intel's website, so this link was not helpfull
    I have already changed the battery of the motherboard but had no sucess.
    Does anybody knows what can I do to fix it?
