MS6 "High temp warning"
Hi Im receiving "Warning high temperature recorded, this could be a house fire", emails from multiple installed MS6 sensors.
Other than winding up the the temperature in the general configuration "high temp sending notification box " is the another solution?
There doesn't seem to be a parameter to stop this in MS6 config. I believe it is a heating issue with MS6 usb powered sensors but whats the fix?
A lot has been written about these "temperature nails" (pulses) from different devices.
But I do not think we have been able to identify what causes them.
My tip is that the "nails" occur in poor communication with the device. I support my theory on my own experiences.
Earlier this autumn, these false alarms occurred several times a week. But now in Christmas times I have not received any false alarm.
I think the extra devices that I have placed for my Christmas lighting have helped to send temperature data without false alarms.
I agree with @RH_Dreambox. Lots of speculation, but nothing really definitive.  I can post some additional links if you want me to. I think it has to do with network and age/type of the device and the problem certainly is not limited to MS6. I do not have a solution. I did some statistical analysis, and I get about 1 in 10000 wrong ( > 45) reports from my sensors (not the MS6).
I only have one MS6 and reporting is OK. But I tried two "crappy" supplies to see if I could get the error, because this was mentioned in another topic. But reporting of my MS6 is still OK. I know the supply is quite bad (actually, "noisy") because I built it myself and I undersized output filtering. But I get no false reporting of any kind.
