Scenes not working for Zwave locks
Andres Cadena
Good day,
i have linked my two zwave locks to my HC2, they work fine from the app, i can control them with not issues. However, when i try to set and scene, to make sure they are closed when needed, the scene does not complete the saving step.
I can add them and set the parameter to "Close", just not saving the Scene to have it running later. I have tried to remove only the locks from the scene and it saves the other steps, i also tried putting the scene only for one lock but still not saving.
Lock types:
- Yale Deadbolt YRD220-ZW-619
- Kwikset 910 zwave
HC2 v.4.150
regards,
Andres
7 answers to this question
I agree its very poor support in the block scenes...I have had some success but it MUST be the last command in the block scene.
  • On 1/2/2018 at 10:40 AM, Piotr Bojko said:
    They should work in Lua scenes. Block scenes are not supported for locks, checked on danalock v3.
    thanks i have them working now with LUA code.
    Question apart from the obvious Lock or Unlock...did you get the conditional ....
    if lock = secure then do ???
    working at all?
    3 hours ago, silvinnio said:
    This is a scene for checking the door.
    Nice one...many thanks
    Sorry to ask a really basic question did you just drop this code into a scene to run ...or a VD?
