Hi there,
Does anyone have a simple scene for the following:
Exhaust Fan can be controlled (and overridden) buy press button. On/Off
If exhaust fan is running for more than 10min, turn off..
Cheers
4 answers to this question
" to "
Temat został przeniesiony z "
" do "
@JamieSonegoAus I don't see you have a condition to automate fan operation except turn if off.  Do you mean you want to manually turn it on, and after a period of time it automatically turns off?
I use McoHome on/off switch together with McoHome Co2 sensor to do the exhausted fan automation, here is the code.
The above code checks if the ppm reading is over 800 from Co2 sensor (ID 93), then trigger on/off switch to turn on (ID 86), else keep it off. Also I have restricted the scene trigger action to run only between 08:00 and 23:59.
If you want to count 10 minutes after an action change (turn on fan in your case), you can use follow code as reference. Make sure the switch can be seen by your fibaro gateway.  You didn't mention how is your exhausted fan wiring.
local lastMod = fibaro:getModificationTime(SwitchID, 'value')
if ((os.time() - lastMod) >= 600000 ) -- more then 10 mins
then
fibaro:call(SwitchID, "TurnOff");
Edited by Sirhideo
then
then
What is ppm? i was planning on doing something similar but use the the humidity sensor if over 70% turn fan on for x minutes after
@Al3x ppm (parts per million) is the measurement of co / co2 density, 1000 is the maximum acceptable level for indoor environment.
Edited by Sirhideo
