Doorbird intercom integration
i try to integrate Doorbird to HC2
any suggestions
Hi @samuel,
Please, try following process to integrate DoorBird:
Document linked above is located here:
I have checked it and tried it. It works as a charm.
@TRicky, I'm glad you have made your camera working. I have made new VD, that works according to new DoorBird API. If you are interested you can check it out:
Guest David86vm
I gott the video image intergrated.
  1. Make a user for you fibaro home center in the Doorbird App.
  2. Add Camera select "Other model"
  3. Fill you username and password
  4. Enter IP adress of your Doorbird
  5. Jpg Path "/bha-api/image.cgi"
  6. Video Path "/bha-api/video.cgi"
That's it.;)
    hi sir
    how to "Make a user for you fibaro home center in the Doorbird App."
    Could you please explain me
    It's working
    but notification request not working:(
    my suggestions
    I found this VD in this forum
    you can do on action do own notification or on soft ring send TurnOn command to any free switch and link switch via a linked device and use it in Fibaro doorbell gateway.
    thanks for your replay sir
    i will try:)
    Yesterday I received my new Intercom; the DoorBird V202.
    After my (not amusing) experiences with my 2N Helios IP Vario, I'm very pleased with this new Intercom!
    The first test results with this DoorBird Intercom are very promising.
    Thanks to @jakub.jezek for the good advise on this matter!
    Would you mind in showing several photos of your new DoorBird and setup ?
    Hi @samuel,
    What would you like to see?
    I only can show you show you the same pics as DoorBird does (I haven't build it in yet, I have to do some drilling and cutting in my wall first).
    About the setup: you have to make a new user in the DoorBird App as descripted in the DoorBird Manual.
    Then add a new camera in Fibaro and use the settings as @David86vm wrote above.
    Then you have the continuous view of the intercom and this works fine.
    I haven't tried the VD as above yet.
    LOL @jakub.jezek,
    Our messages crossed!
    Thanks a lot!
    Even the VD works great (Door opener & IR Led); you only have to be beware on what to change in the settings!
    Hi all!
    Is it possible to integrate DoorBird like the Fibaro Intercom into scenes?
    Alex
    Edited by schata
    I attached 2 Fibaro UBS sensors to my DoorBird Intercom.
    UBS 1-1 to the external chime output (to activate my doorbells)
    UBS 1-2 to the DoorBird door opener output (this activates the scene that opens my gate)
    UBS 2-1 to a microswitch I placed inside the housing of my DoorBird to warn me in case of tampering
    Further On I use the VD as written by @jakub.jezek
    Did anyone manage to send a HTTP request from the Doorbird to the Fibaro when opening the relay?
    I managed to do so for the motion sensor and the door bell but haven't found a way to notify the HC2 of an opened relay (ideally without using a UBS).
    Would love to use that trigger to open the Z-wave lock...
    Thanks for your help!
    Karsten
    Hello Guys,
    I will check DoorBird probably this week regarding HTTP request. I saw there some settings regarding http requests, but no promises. If it will work, then i will check with Doorbird regarding http commands.
    Jakub
    Thanks Jakub.
    To clarify: the http requests work very well for motion detection and the door bell (triggering scenes through the fibaro api).
    I just haven’t found a solution for requests associated with triggering the relay.
    Thanks.
    Karsten
    Hmmmm, you probably need to check with event monitoring UDP api. But i do not know if it will be possible in HC2. With TCP it monitors something like ioboundary, but it could be relay and input together.
    API page 26/36:
    Thanks for this. The latest doorbird app (released today) together with the latest firmware actually has the functionality I was looking for. Wish it was always that easy... thanks everyone. Karsten
    Is it in some way possible to see in HC2 if the relay has been triggered. So I can open my z-wave lock. The VD and everyting works perfect but I dont see what to do with it in HC2 that I can not do in Doorbird app
