IP Device Local Network Detector & Scene
I have below script VD in LUA which detect my phone IP in network - works good :]
Cytuj
fibaro:call(45,"setProperty","ui.Label111.value","start");
local _deviceIp = "192.168.0.4";
local _devicePort = 53516;
local _maxRetryProcess = 5;
-- recursive function to ping device
local function _ping(retry)
  retry = retry or 0;
  --open the socket
  local tcpSocket = Net.FTcpSocket(_deviceIp, _devicePort);
  --set the read timeout
  tcpSocket:setReadTimeout(250);
  --notify user
  fibaro:call(45,"setProperty","ui.Label111.value","szukam");
  fibaro:sleep(250);
  --send packet
  local bytes, errorCode = tcpSocket:write("ping");
  --check for error
  if errorCode == 0 then
      return true;
  else
      if retry < _maxRetryProcess then
        fibaro:call(45,"setProperty","ui.Label111.value","powtarzam szukanie");
        fibaro:sleep(1000);
      return _ping(retry + 1);
    return false;
--ping device, secure with pcall to catch errors.
local f, result = pcall(_ping);
if (f) then
  if (result == true) then
    fibaro:call(45,"setProperty","ui.Label111.value","W zasiegu");
    fibaro:setGlobal("remo", "1");
  else
    fibaro:log("Server was not found!");
    fibaro:call(45,"setProperty","ui.Label111.value","Poza zasiegiem");
    fibaro:setGlobal("remo", "-1");
else
  fibaro:call(45,"setProperty","ui.Label111.value","błąd");
Now question - how can i must create scene with blocks ? after detect my phone in local network switch lights or etc...... Must first make variable or how?
Please help really dont know, try since few hours :/
4 answers to this question
There are many ways to detect your phone or make auto lights go on it. And yes you must make global variables.
I have 3 phones to detect with 3 globals with 0 and 1 for example. all 3 with the precense detector on 0 and home status goes on Away... > lights of ;)
1 motion sensor in hall or 1 of the 3 phones on 1 home status goes on Home > lights On :D and you can go on like that...
See my signature for some solutions I use from great people that are around here
    I dont have motion sensor yet. I just start journey with fibaro
    on phone installed Tasker and app FTP server :)
