Hi guys and especially @petergebruers,
First of all sorry for dragging you into this @petergebruers, I mentioned you here because I highly respect your input and knowledge and if anyone knows you are the one.
Is there any GU10-Led dimmable that comes close to dimmable capabilities of a halogeen GU10?
I have some Philips dimmable GU10 LED's but they don't measure up to the halogen GU10's.
Hoping someone can advice me.
Jim
9 answers to this question
I like these. They're called "warm glow" and simulate halogen by shifting towards orange when dimmed down. I own several of them but with E27, not GU10
Oops! When I clicked through on that link, then on "GU10" on the uk site I noticed: "Unfortunately this product is no longer available". That is disappointing!
Edited by petergebruers
    Thanks Peter, will look for replacement!
    Have a good weekend!
    Found them:
    Little update I ordered these:
     will report back!
    Guest chaicka
    I came across Philips Hue GU10 bulb (
    ) some time back. Too bad it is still not available in where I am located. Been asking Philips about its availability without a firm answer. Not sure if it fits what you are looking for and if it is available where you are.
    Thanks @chaicka, I have 2 of them over the side table in the living at the moment. the are Hue lights and cant be controlled by a dimmer.
    I Installed the warmglow GU10's just now. They are brilliant! they dim back really far compared to "normal" GU10 LED's and you get the same kind of glow a halogene bulb gives.
    Thanks again @petergebruers for the suggestion.
    Jim
    Guest chaicka
    That's good news. I am looking for GU10 dimmable to replace current non-dimmable non-Philips bulb too as I need it to be very dim (to shine on a fortune gathering bowl - bit of feng shui). Thanks for sharing and I will see if what you gotten is available here. Just curious. You using Fibaro Dimmer 2 or the older Dimmer to control this GU10 LED?
    I use a dimmer2, these are the LED's I got:
    Indeed! Lighting is a personal thing... I'm glad you like them!
    I use both dimmer 1 and dimmer 2 on the E27 variant of the "Philips Warm Glow". I doubt there is much difference in behaviour between the different socket types. On Dimmer 1 I had to add a "bypass 1" because the leakage current through Dimmer 1 makes them glow faintly when turned off. Bypass 1 solves this issue.
    Guest chaicka
    Thanks jimicr and petergebruers. You guys know exactly what I was asking/concern on and answered perfectly.
    Guess I will just go for Dimmer 2 when I get my hands on the same Philips GU10 LED.
