DW sensor + PIR
julesmartens
Hi all,
I have a DW sensor that should switch on the light when it is evening and the door is open.
Once triggered, the light should remain on until the door is closed and no motion is detected in that room.
When door is closed and motion is no longer detected the light should slowly fade out.
I wrote below code for this but cant get it working properly.
I have the problem that the light will perfectly go when the door is opened but it will not go out!
Anybody an idea what I do wrong? It seems not to reach the "repeat" part of my code which is within the IF statement.
Here is the code:
%% autostart
%% properties
21 value
127 value
%% weather
%% events
%% globals
omtrekverlichting
--============ HOME TABLE =======================
fibaro:getGlobalValue("HomeTable")
local jT = json.decode(fibaro:getGlobalValue("HomeTable"))
-- used devices and its id
fibaro:debug("device: hal - voordeur DW = ID: " ..jT.hal.voordeursensor) --127
fibaro:debug("device: hal - hal PIR = ID: " ..jT.hal.HalMo21) --21
fibaro:debug("device: hal - duospot = ID: " ..jT.hal.duospot) --160
fibaro:debug("device: hal - halspot = ID: " ..jT.hal.halspot) --116
local debug = false
Debug = function (debug,color, message )
  if (debug) then
      fibaro:debug(os.date("%x")..string.format('<%s style="color:%s;">%s</%s>', "span", color, message, "span"));
if (fibaro:countScenes() > 1) then
    Debug( true,"purple", " too many instances --> abort ");
      fibaro:abort()
local trigger = fibaro:getSourceTrigger()
if (trigger['type'] == 'property')         then Debug(true, "Grey", ' scene triggered by - Source device = ' .. trigger['deviceID'])
elseif (trigger['type'] == 'global')     then Debug(true, "Grey", ' scene triggered by - Global variable source = ' .. trigger['name'])
elseif (trigger['type'] == 'other')     then Debug(true, "Grey", ' scene triggered by - Other source')
-- start up ---------------------------------------
local deurstatus = fibaro:getValue(jT.hal.voordeursensor, "value")
local Darkness = fibaro:getGlobalValue("Darkness")
local motion = fibaro:getValue(jT.hal.HalMo21, "value")
local lampstatus = fibaro:getValue(jT.hal.duospot, "value")
local dimlevel = 60
if     (tonumber(Darkness) == 1) and (tonumber(deurstatus) == 1) then
                  Debug( true,"Orange",' hal verlichting ingeschakeld')
                  fibaro:call(jT.hal.duospot , 'setValue' , dimlevel)
                  fibaro:call(jT.hal.halspot , 'setValue' , dimlevel)
                  repeat fibaro:sleep(3*1000) -- always wait at least x seconds before fade out.
                  until (tonumber(motion) == 0) and (tonumber(deurstatus) == 0)
                 while( dimlevel > 10 )       do -- start fade -out.
                 fibaro:sleep(20)
                 Debug( true,"Yellow",' dimlevel is '..dimlevel)
                dimlevel = (dimlevel -0.4)
      fibaro:call(jT.hal.duospot , 'turnOff' ) -- make sure lights are really off
      fibaro:call(jT.hal.halspot , 'turnOff' )
      Debug( true,"Green",' hal verlichting uitgeschakeld')
Edited by 10der
