Sonoff basic
wiesiekr
Hello.
Does anyone have an idea how to make a virtual device to control Sonoff Basic with the loaded espeasy or other software so that you can switch on and off the device with the HCL.
  Is it possible to read states in the HCL or is switched on or off.
LUA. :(
but as I can see HCL can send "telnet" command.
so you can send
/cm?cmnd=Power1%20ON or /cm?cmnd=Power1%20OFF
command as "string"
Edited by 10der
Yes by send GET command via http in VD button
(in VD IP zone write IP address of remote server and in PORT remote http port ex. 80)
  • Wpisałem w VD IP sonoffa oraz port 80, w przycisku wpisałem
    cm? Cmnd = GPIO12.1Moc1% 20OFF
    HTTP / 1.10x0D0x0A0x0D0x0A
    lecz dalej nie działa
    Wpisałem w VD IP sonoffa oraz port 80, w tym wpisie
    Edited by wiesiekr
    30 minutes ago, wiesiekr said:
    Czy masz może gotowe VD do HCL pod Sonoffa ?
    witam. nie. ja mam HC2. LUA VD :(
    to forum blad :(
  • The device is working properly
    GET /control?cmd=GPIO,12,1 HTTP/1.1
    Host: 192.168.1.xxx
    0x0D0x0A0x0D0x0A
    Thank you very much for help.
    witam.
    Próbowałem  uruchomić podane przez Ciebie VD
      i mi to nie działa. Co należy uzupełnić lub zmienić
    w zakładce ogólne adres IP i port 80 oraz w ikonki
    Witam
    działa z najnowszymi wersjami flash firmware (json response)
    32 minutes ago, ptactwo said:
    Czyli wgrać najnowsze oprogramowanie ESPEasy_v2.0-20180316
    ¯ \ _ (ツ) _ / ¯
    Can I get more help here. This is my first time adding a VD on my HCL and I have added the code above but still it is not working.
    I wonder what is the reason and I also feel it is strange to work without username and password!
    Appreciate your help friends...
    11 hours ago, 10der said:
    No. HCL does not support LUA.
    but you can call via HTTP
    Thanks, but how to do that? :roll:
    Any idea? HTTP Call did not work with me even directly through the browser. I'm using Sonoff S20
    did anyone have any success with http command.....? I would really like to add the sonoff switches to HCL....
    Assuming you have flashed the device with Tasmota , adjust IP to suit
    note: there is a space in the command string that is represented by the typical %20 representation
    Sonoff basic
    On - http://192.168.1.153/cm?cmnd=Power%20On
    Off - http://192.168.1.153/cm?cmnd=Power%20Off
    Dim - http://192.168.1.153//cm?cmnd=Power%20TOGGLE
    http://192.168.1.153/cm?cmnd=status%200 (full status in in browser or HC2)
    MagicHome
    same as above but also has dimmer
    x is dim value between 0 and 100
    http://192.168.1.153/cm?cmnd=dimmer%20"..x
    Dimmer with slider in VD
    Fade off VD button
    Fade off button
    Same as above but replace
    with
    100 - start value, 0 - end value, 1 - decrement value
    Magichome
    Counter Lights VD  (this controls 2 RGB modules, colors displayed by the presets may vary with your led strip)
    Sonoff basic
    running a lamp
    Sonoff TH16 with Temp/Humidity sensor
    Running a bathroom extractor fan (sensor above fan in extractor tube)
    /monthly_2018_09/image.png.ecdbb2652a9cac1a750b91d788ebea36.png" alt="image.png.ecdbb2652a9cac1a750b91d788ebea36.png" />
    Edited by AutoFrank
    Hi, I try the
    But don't work. Are you sure that it's ok?
    I know that Magic Home use port 5577.
    Sonoff basic
    MagicHome
    Fade off VD button
    Fade off button
    with
    Magichome
    Sonoff basic
    running a lamp
    Since a while there is a new Sonoff firmware available, that provides a so called "inching" feature, this would have the effect of a pushbutton, so it only closes the pins of the relay for a time equal or greater than 0,5 seconds. This is a perfect solution to open/close a garage door.
    On the other side I was disappointed to see, that Tasmota will not provide such functionality, yet there might be a command for that which in turn could be adapted so that Fibaro HC2 could send a pulse only to the Sonoff.
    Is there such a command available that I could use? How would you solve my issue?
    Hello. I have a script adapted by @Auto Frank "Extractor_Fan.vfib". The problem is that it does not change my status from On to Off in the module. Please help. I am enclosing the script from the main loop.
    local device    = fibaro:getSelfId()
    local zone         = fibaro:getName(device)
    local ipaddress = fibaro:getValue(device, "IPAddress")
    local port         = fibaro:getValue(device, "TCPPort")
    s = Net.FHttp(ipaddress, port)
    rS1 = s:GET("/cm?cmnd=Status")
    rS2 = s:GET("/cm?cmnd=Status%2010")
    if rS1 ~= nil and rS1 ~= "" then
          jS = json.decode(rS1)
          if jS.Status.Power == 0 then
               fibaro:call(device,"setProperty","ui.extfan.value", "Off")
          fibaro:call(device, "setProperty", "currentIcon", 1085)
            fibaro:setGlobal("SonoffFanGuestEns", 0)
            fibaro:debug("fan is off")
           elseif jS.Status.Power == 1 then
              fibaro:call(device,"setProperty","ui.extfan.value", "On")
            fibaro:call(device, "setProperty", "currentIcon", 1006)
            fibaro:setGlobal("SonoffFanGuestEns", 1)
               fibaro:debug("fan is on")
    else
      fibaro:debug("Sonoff appears to be offline")
      fibaro:call(device,"setProperty","ui.status.value", "OFFLINE")
    if rS2 ~= nil and rS2 ~= "" then
          jS = json.decode(rS2)
          local Temp = jS.StatusSNS.DHT11.Temperature
          local Humidity = jS.StatusSNS.DHT11.Humidity
          fibaro:setGlobal("SonoffFanGuestEnsT", Temp)
          fibaro:setGlobal("SonoffFanGuestEnsH", Humidity)
           fibaro:call(device,"setProperty","ui.temp.value", Temp.." C")
        fibaro:call(device,"setProperty","ui.humidity.value", Humidity.." RH")
          local fanState = fibaro:getGlobalValue("SonoffFanGuestEns")
          if fanState == "1" then fanStat = "Off" else fanStat = "On" end
        status = ""..fanStat.." / "..Temp.." C / "..Humidity.." RH"
          fibaro:debug(status)
          fibaro:call(device,"setProperty","ui.status.value",status)
    local upt = ""..os.date("%d").." "..os.date("%b").." @ "..os.date("%H:%M")..""
    fibaro:log("Updated: "..upt)
    fibaro:sleep(5000)
