wiesiekr 6
Hello.
Does anyone have an idea how to make a virtual device to control Sonoff Basic with the loaded espeasy or other software so that you can switch on and off the device with the HCL.
Is it possible to read states in the HCL or is switched on or off.
31
4
3
Dec 22
30
Mar 16
8
Dec 1
7
Nov 30
6
10der 35 posts
ptekien 31 posts
wiesiekr 4 posts
nahhab 3 posts
Dec 22 2019
Mar 16 2018
Dec 1 2019
Nov 30 2019
AutoFrank
Assuming you have flashed the device with Tasmota , adjust IP to suit note: there is a space in the command string that is represented by the typical %20 representation Sonoff basic
ptekien
I converted this script a bit into single Sonoff 4CH or 4CH pro channels. As if someone needed to control independently as it is e.g. in double switch fibaro. Maybe it will be useful to someone.
10der
Universal Sonoff device for example 2x relays Please login or register to see this image. /monthly_2019_12/image.png.fdc2d893f8e8c6a7793b1f5300b0470a.png" /> for example 4x
89 answers to this question
