Hello.
Does anyone have an idea how to make a virtual device to control Sonoff Basic with the loaded espeasy or other software so that you can switch on and off the device with the HCL.
  Is it possible to read states in the HCL or is switched on or off.
thanks!
i do not know.
all work like a charm
/monthly_2019_12/image.png.40bdc024bf8f8204dcfd1bc3b2bc1d0f.png" />
in attach "patched" for you VD.
wszystkiego najlepszego..
5 minut temu, 10der napisał:
i do not know.
I don't know why, but for me this VD doesn't work at all. As I delete from the code ["AM2301"] it works but does not show temperature and humidity.
/monthly_2019_12/image.png.5f094d2e9bbd17932977582ceb6a6e3d.png" />
you privide me nice response. this response is really OK
more than with this response VD works OK.
one monent I will include some debug info for u
debug
/monthly_2019_12/image.png.277aea09cd01956dd0ee68efac7be624.png" />
smutek...
debug #2
/monthly_2019_12/image.png.d6ba4938de913cca7624d498c943348b.png" />
czy mozesz zapisac  w file?
nie .png / jpg :)
your response does not contain any sensors states!
as I type in the browser:
http://192.168.1.6/cm?cmnd=status%2000
I get an answer
/monthly_2019_12/image.png.bde60766895b11ae762667e20696eddd.png" />
when you caling in your web briwser somthing like
you MUST rcvd response WITH sensors states (temp + hum for example)
otherwise it's:
1) Tasmota FW bug
2) wrong configuration (for example all response sending to MQTT)
3) others
i do not know what 2000 is.
please point me to doc, please
PS:
add (change) to
function updateStatus()
local resp, status, result = rPi:GET("/cm?cmnd=status");
local resp, status, result = rPi:GET("/cm?cmnd=status%2000");
but i do not know what is "00"
W dniu 25.09.2018 o 21:16, AutoFrank napisał:
Assuming you have flashed the device with Tasmota , adjust IP to suit
note: there is a space in the command string that is represented by the typical %20 representation
Sonoff basic
On - http://192.168.1.153/cm?cmnd=Power%20On
Off - http://192.168.1.153/cm?cmnd=Power%20Off
Dim - http://192.168.1.153//cm?cmnd=Power%20TOGGLE
http://192.168.1.153/cm?cmnd=status%200 (full status in in browser or HC2)
MagicHome
same as above but also has dimmer
x is dim value between 0 and 100
http://192.168.1.153/cm?cmnd=dimmer%20"..x
Dimmer with slider in VD
Fade off VD button
Fade off button
Same as above but replace
with
100 - start value, 0 - end value, 1 - decrement value
Magichome
Counter Lights VD  (this controls 2 RGB modules, colors displayed by the presets may vary with your led strip)
Sonoff basic
running a lamp
Sonoff TH16 with Temp/Humidity sensor
Running a bathroom extractor fan (sensor above fan in extractor tube)
I took this command from VD which works and shows temperature and humidity
thank you VERY much for collaborating!
attached
5 mins, please!
make universal version!
pay attention!
-- how many switches!
local model = 2
--  what sensor type
--- if NO sensors = nil
local sensorType = "AM2301"
--  "AM2301" / "BMP280" / "DHT11" / etc
-- for Sonoff SC = empty string = ""
Hi 10der,
I'm completely new here with Fibaro and VD for Sonoff. What I miss is if I have to update Sonoff with  Tasmota before using your .vfib.
Thank for your understanding
miss?
- native sonooff clouds access
- native application from sonooff
