Menu not working as expected
thoemmeli
The keyfob manual v1.1 describes the menu as follows:
Menu allows to perform Z-Wave network actions. In order to use the
menu:
1. Click CIRCLE and MINUS simultaneously.
2. Click TRIANGLE or CROSS until LED indicates desired menu position with colour:
• White - wake up the device
• Green - learning mode (adding/removing)
• Cyan - check battery level
• Yellow - reset the device*
3. Click PLUS to confirm selection, Click MINUS to exit the menu.
4. LED will pulse twice with same colour as selected menu position
to confirm completing action.
I have followed these instructions, but already at step 2, the LED does not come alive no matter how long I press TRIANGLE or CROSS.
Any help is highly appreciated.
Cheers
  • When I press circle and minus simultaneously the white LED shows for a few seconds.
    This happened to me once, but i managed to reset keyfob (fast fingers) and then menu started working as expected.
