I recently took out my HC2, reset and updated it, and added two Fibaro Dimmer 2's. The dimmers are functioning normally,  but the interface shows these additional devices, with a "remote control" being visible and others being hidden. Can anyone clarify what these are please?
EDIT: It is also showing me a firmware update available for both dimmers but they are for the hidden (8.0 and 4.0) devices and not the visible ones.
Thanks!
PG
Edited by pg12575
  • 2
The Remote is "S2" / switch2 on your dimmer. It makes it possible to put a double momentary switch and let you control other devices through assosiations. I use this to control lights in the room outside the one I am in.
Guest David86vm
Hi PG,
Did you already found out how this happend yesterday I added a dimmer and also have a remote as a bonus
    @David86vm No idea, was hoping someone else could enlighten me..
