Slim! domotica 0
Hi, I'm trying to program a Danfoss wall thermostat within the HC2.
purpose is that the thermostat switches a single switch when the temperature requested is higher then the actual temperature and do the opposit when the the desired temperatur is below the actual temperature.
within the HC2 I can see both thermostat values, the actual and the setpoint, also the single switch is visible.
can anyone help me on how to make this work?
