dimae
Finally, a HC2 / HCL Workaround to RTSP / H.264 IP Cameras - 100% Working solution
Hi all,
I would like to share a 100% working solution for HC2 / HCL users that want to use new IP cameras working with RTSP, H.264.
Problem: as you know Fibaro doesn't respect too much users demands. Fibaro only supports old IP cameras working with old streaming methods like MJPEG, using basic authentification... This is very bad, because it forces us to use old and unsecure technology. The best solution is that Fibaro supports newer protocols, RSTP, H.264, SSL authentication... But as you know, taking care of users is not the main Fibaro interest.
Workaround solution: using an old Android phone (or tablet) as a webserver proxy using
awesome app (3,5 EUR cost). The main idea is that tinyCam Monitor PRO connects to your cameras, serving at real-time MJPEG streams that Fibaro can watch perfectly fine :-)
Yes, it sounds too naif but for me, it toke me years in order to find this solution...
In my example we will use Foscam C1
  • You should take care of user, password, IP including port (the same that you setup at tinyCam Monitor PRO Webserver)
  • JPG path: axis-cgi/jpg/image.cgi?camera=1
  • MJPG path: axis-cgi/jpg/image.cgi?camera=1
  • Check [ JPG ] 3 s. and Show it on main screen and [ v ] Send STOP
    If you have more than one camera, you need to add another IP Camera on Fibaro with exact configuration, but you should change in JPG and MJPG paths, camera=2, camera=3... and so on
    That's all!
    I hope you like it and it helps you :-)
    • Like 6
    Share this post
    Link to post
    " to "
    Temat został przeniesiony z "
    " do "
    Share this post
    Link to post
    Finally a feasible solution. @dimae, u are absolutely right that support for modern IP Cams are way lacking in HC2/HCL. MJPEG is so obsoleted, and those security risks you have mentioned.
    I had trouble to include UniFi Video Cameras to HC2 without causing serious issues that I have to take the UVCs out from HC2.
    Share this post
    Link to post
    15 hours ago, dimae said:
    Hi all,
    I would like to share a 100% working solution for HC2 / HCL users that want to use new IP cameras working with RSTP, H.264.
    Someone please give him an award!  @dimae
    Share this post
    Link to post
    hi!
    alternative solution - use own web server (for example rpi)
    create php file with content
    192.168.1.32 your rtsp cam
    Share this post
    Link to post
    Hi @10der do you mind to elaborate for non programmer like me?
    How do i create an php file to decode rtsp into mjpeg?
    in the example seems like it is converting into jpeg instead of mjpeg
    192.168.1.28  = rasp ip?
    what if there's more than 1 camera?
    Thanks in advance =)
    Share this post
    Link to post
    I guess you could create 2 files, camera1.php, camera2.php and so on... However this method requires more skills, too hard for me ;-)
    36 minutes ago, 10der said:
    hi!
    thanks for sharing it! Can you please share how to stop/start services, what is required? where to put camera.php and so?
    Thanks!
    Share this post
    Link to post
    3
    foscam
    http://192.168.1.28/camera.php?usr=admin&pwd=admin&ip=192.168.1.15
    btw
    foscam have a native command
    http://192.168.1.15:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=admin
    Edited by 10der
    Share this post
    Link to post
    Just now, Sjekke said:
    Is it possible to run this on a Synology NAS, Docker?
    it works on my QNAP without docker
    Share this post
    Link to post
    very interesting!
    so you need to php running, what else? I asked you before... and I am asking today again :-), if you don't mind, could you please share it? I mean, what software is needed? Php? codec? any libs?
    super thanks
    Edited by dimae
    Share this post
    Link to post
    here is script
    here is how to use
    its' Xiaomi Ants Xiaoyi Smart Camera Night Vision with RSTP only protocol
    fields user and password pass-thru via basic auth to script
    JPG path. and MJPG path.
    /camera.php?ip=192.168.1.32:554&endpoint=ch0_1.h264
    notice:
    Edited by 10der
    • Thanks 2
    Share this post
    Link to post
  • WoW! Thanks!
    I will try it for sure. Thank you
    Share this post
    Link to post
    On 5/11/2018 at 8:13 PM, dimae said:
    WoW! Thanks!
    Hi @dimae
    did you tried it?
    Share this post
    Link to post
  • On 6/3/2018 at 10:11 PM, Sjekke said:
    Hi @dimae
    did you tried it?
    no chance for experiments yet :-(
    Share this post
    Link to post
    On 4/23/2018 at 1:40 PM, dimae said:
    Hallo zusammen,
    Ich möchte eine 100% -ige Arbeitslösung für HC2 / HCL-Benutzer freigeben, die neue IP-Kameras verwenden möchten, die mit RSTP, H.264 arbeiten.
    Problem : Wie Sie wissen, respektiert Fibaro nicht zu viele Benutzeranforderungen. Fibaro unterstützt nur alte IP-Kameras, die mit alten Streaming-Methoden wie MJPEG arbeiten, mit einer grundlegenden Authentifizierung ... Das ist sehr schlecht, weil es uns zwingt, alte und unsichere Technologie zu verwenden. Die beste Lösung ist, dass Fibaro neuere Protokolle, RSTP, H.264, SSL-Authentifizierung unterstützt ... Aber wie Sie wissen, ist die Pflege der Benutzer nicht das wichtigste Interesse von Fibaro.
    Workaround-Lösung: Verwenden Sie ein altes Android-Telefon (oder Tablet) als Webserver Proxy mit
    App (3,5 EUR Kosten). Die Hauptidee ist, dass der tinyCam Monitor PRO mit Ihren Kameras verbunden ist und Echtzeit-MJPEG-Streams bereitstellt, die Fibaro perfekt überwachen kann:-)
    Ja, es klingt zu naiv, aber für mich hat es mich Jahre gekümmert, um diese Lösung zu finden ...
    In meinem Beispiel werden wir Foscam C1 verwenden
    Tinycam Monitor Pro Konfiguration:
    1. Installieren Sie
      auf Ihrem alten Android-Telefon im selben Netzwerk wie Ihre HC2 / HCL und stellen Sie sicher, dass Ihr Telefon rund um die Uhr funktioniert, wie es bei Ihren Kameras der Fall ist .u9U1qxL.png
    2. Konfigurieren Sie Ihre Kamera wie gewohnt
    3. Gehe zu tinyCam Monitor PRO / menu / Einstellungen / Web Server, setze ein starkes Admin-Passwort und wähle einen Port (ich benutze den Standard-Port 8083).
    4. Gehen Sie zu tinyCam Monitor PRO / menú / Aktivieren Sie den Webserver und überprüfen Sie die Nachricht: "Der Webserver läuft unter http://192.168.1.10:8083"
    5. Testen Sie es in Ihrem Computerbrowser, Google Chrome als Beispiel und melden Sie sich mit Ihrem Admin / Passwort von Schritt 3 an. Sie werden einen Begrüßungsbildschirm mit einigen Informationen sehen können. Ich empfehle, dass Sie "Hintergrund-Modus" und "Power-Safe-Modus" aktivieren. In meinem Fall habe ich 2 x RSTP H.264 IP-Kamera und verwendet etwa 30% CPU (2014 Android-Handy).
    Fibaro HC2 Konfiguration:
    1. Fügen Sie eine neue IP-Kamera hinzu, wählen Sie als Modell  Axis Generic und gehen Sie zur Registerkarte Erweitert
    2. Sie sollten sich um Benutzer, Passwort, IP einschließlich Port kümmern (das selbe, das Sie auf dem tinyCam Monitor PRO Webserver eingerichtet haben)
    3. JPG-Pfad: axis-cgi / jpg / image.cgi? Kamera = 1
    4. MJPG-Pfad: axis-cgi / jpg / image.cgi? Kamera = 1
    5. Überprüfen Sie [JPG] 3 s. und Zeige es auf dem Hauptbildschirm und [v] Sende STOP
    Wenn Sie mehr als eine Kamera haben, müssen Sie eine weitere IP-Kamera auf Fibaro mit genauer Konfiguration hinzufügen, aber Sie sollten in JPG und MJPG Pfaden ändern, Kamera = 2, Kamera = 3 ... und so weiter
    Das ist alles!
    Ich hoffe es gefällt dir und es hilft dir :-)
    Hallo,
    wenn ich die =Kamera 2 einstelle habe ich immer Bild von der ersten Kamera
    Gibt es da eine Lösung?
    Grüße
    Share this post
    Link to post
    Guest Sebdb66
    Is there a version of TinyCam Monitor Pro (or some other software) that would run on a Raspberry PI , so the conversion could look a little more professional than having an always on Android phone ?
    Share this post
    Link to post
    FFMPEG. Plenty of tutorials on the Web. Here is a good start:
    Share this post
    Link to post
