10der 649 Share Posted January 1, 2020 fibaro issues. alas. fibaro Ui do not update cam state anymore. 5 cams + 1cam with my proxy with same behavior. that's' all folks. Quote Link to post Share on other sites
RH_Dreambox 86 Share Posted January 9, 2020 @10der Have you managed to fix the problem of not updating the video image? Thanks to your script, I get video (still image) from my TX-67 and I can also take snapshots. But I miss moving pictures (and controlling the camera). My Raspberry cameras are updating properly so there is probably no error in the GUI. I now also know why the TX-67 can no longer be integrated into Fibaro, see below. Quote Dahua IP cameras are NOT supported anymore. In fact, most IP cameras with latest firmware will stop working very soon. Here's why: - Recent vulnerabilities have forced manufacturers to REMOVE basic authentication. - Digest authentication has become the LOWEST security mechanism - its one step above plain text authentication (visible in packet capture). - In Dahua firmware from early 2017, basic authentication is blocked. - Dahua has BLOCKED the ability to downgrade to firmware with basic authentication (firmware is signed). Fibaro MUST add digest authentication for IP cams to keep us at the current level. 1 Quote Link to post Share on other sites
10der 649 Share Posted January 9, 2020 (edited) 4 minutes ago, RH_Dreambox said: Have you managed to fix the problem of not updating the video image? I am not Fibaro developer. Edited January 9, 2020 by 10der Quote Link to post Share on other sites
RH_Dreambox 86 Share Posted January 9, 2020 @ 10der I know But you mentioned that you would look at your php script to see what was wrong. Or do you mean that Fibaro fails to update your script? My Pi cameras are updating properly. Quote Link to post Share on other sites
10der 649 Share Posted January 9, 2020 @RH_Dreambox OMG. dear. please read: Quote Posted January 1 fibaro issues. alas. fibaro Ui do not update cam state anymore. 5 cams + 1cam with my proxy with same behavior. that's' all folks . i have the same behavior Quote Link to post Share on other sites
Jon557 0 Share Posted April 9, 2020 On 4/24/2018 at 9:15 AM, 10der said: http://192.168.1.15:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=admin&pwd=admin Awesome! This I think is good enough for me thanks! I just set the refresh to 1 or 2 seconds and I get the just of what is going on. I might get up a Pi at a later date to serve. Cheers, Jon Quote Link to post Share on other sites
Brendanlim 0 Share Posted July 15, 2020 Hi, I can load my IP Cam images in browser via local connection with IP address. However, I can't load any images from remote access via browser or APP. Here are some of my IP Cam info: IP address : 192.168.0.105 JPG, MJPG route : cgi-bin/hi3510/snap.cgi?&-getstream&-chn=2 The route is copied from the IP Cam's inspect from browser. Quote Link to post Share on other sites
storskogen 4 Share Posted August 2, 2020 On 7/15/2020 at 8:50 AM, Brendanlim said: Hi, I can load my IP Cam images in browser via local connection with IP address. However, I can't load any images from remote access via browser or APP. Here are some of my IP Cam info: IP address : 192.168.0.105 JPG, MJPG route : cgi-bin/hi3510/snap.cgi?&-getstream&-chn=2 The route is copied from the IP Cam's inspect from browser. Do you have a IP gateway set in the camera? Quote Link to post Share on other sites
freespirits 0 Share Posted August 13, 2020 (edited) Hello Is this still working or not? I managed to install TinyCam Pro, it's running on an old Android tablet and I can see the camera from there. If i start the webserver, and i go to tablet IP:port i can see the webinterface with cams. Also if I check via chrome adress "http://192.168.0.8:8083/axis-cgi/mjpg/video.cgi?camera=1" I can see the images (i found this link in the API manual section of Tinycam). Link with axis-cgi/jpg/image.cgi?camera=1 it's not working at all. No trace of plain JPG link in api manual. Of course this is not working at all in FIBARO HC2 (will not work even using MJPG in both links and selecting MJPG in "Display camera image at Your House, advanced options:".) Is this still working for some of you guys or it's broken? Tnx for Help Nicola Edited August 13, 2020 by freespirits Quote Link to post Share on other sites
freespirits 0 Share Posted August 13, 2020 (edited) Oh well... I found out the solution of the problem by myself.... As I said i was using an old tablet. Looks like Android version matters for APIs API and webinterface are completely different in old tablet (i guess playstore is giving me an old version of tinycam since it has to run in JellyBean). This is API manual with tablet: And this is with my phone Of course is now working prefectly on Fibaro : ) Edited August 13, 2020 by freespirits Quote Link to post Share on other sites
RH_Dreambox 86 Share Posted August 14, 2020 @freespirits You need to add the camera's IP address and port number to your HC2. Then it should work. Is a username and password not required for you to access the camera? Quote Link to post Share on other sites
texan 3 Share Posted August 14, 2020 I bought an Automationbridge pro, with that you can add ip cameras (rtsp). Quote Link to post Share on other sites
freespirits 0 Share Posted August 14, 2020 (edited) 26 minutes ago, RH_Dreambox said: @freespirits You need to add the camera's IP address and port number to your HC2. Then it should work. Is a username and password not required for you to access the camera? Ye, IP was just missing on the screenshot. As I said it was an app version issue due to tablet being too old. I have resolved now. Thanks for reply tho Edited August 14, 2020 by freespirits Quote Link to post Share on other sites
clowg 10 Share Posted September 21, 2020 On 8/14/2020 at 8:37 PM, texan said: I bought an Automationbridge pro, with that you can add ip cameras (rtsp). Tell us more! What does it enable in HC2? Quote Link to post Share on other sites
texan 3 Share Posted September 21, 2020 Bought the non upgrade (there was no upgrade at that time) Wanted to use my HIK cameras with RTSP. https://store.skaro.com.au/product/automationbridge-pro-upgrade/ Supported Cameras are : D-Link, Hikvision, other cameras can be added if they support RTSP/H.264 and you have the required URL’s Quote Link to post Share on other sites
Rodolfo 2 Share Posted December 4, 2020 I bought 1 raspberry pi and a home assistant just to not be held hostage only by fibaro. Why is fibaro not updated and allows you to add all types of ips cameras? Quote Link to post Share on other sites
