My Home center lite seems to hang up after a while, more and more common, the only thing that solves the problem is to restart it. It often happens when logging into home center via the mac. I have now 13 devices, wonder if it can have something to do with the memory? Or is there any way to refresh it? Or can it have something to do with the new Beta version 4.501 ? This is my second Home Center Lite. The first started to get buggy after some month. Anyone with the same problem?
Regards Øystein Krossli
4 answers to this question
i'm having the same problem...waiting for another upgrade...
Same here
after i installed 4.501 beta de unit Will stop werking at leest ones a day
i can’t restore previous version.
W
Hi, it may be possible to restore a previous version by using recovery mode. you can download some previous versions of the firmware from
  • http://updatehcl.fibaro.com/4.170/patch.tar.gz
where 4.170 is the version you are trying to download.
Once downloaded enter recovery mode, choose repair from file using the file you just downloaded and wait.
This should take the firmware of your device back to 4.170.
if you cant login either using your normal super user login or admin then go back into recovery mode and choose the recover system option.
This will reinstall a blank version of 4.170, login as admin and then restore one of your backups.
Its slow but it seems to work.
Thanks to http://domotica4all.com/book-review/tutorial-how-to-downgrade-firware-version-of-z-wave-controller-fibaro-home-center-2-or-home-center-lite/ for getting me started on this.
Just installed the update and I'm trying to find a solution myself. It seems like every two or three commands it freezes then becomes unavailable.
