1608chris 0
hi,
i’m new here and need some help with my install of a Fibaro FGR-222. All appears correctly installed, but the shutters won’t move to calibrate (flashing LED) and when i tested the relays by switching around my toggle switches of S1 & S2 it looks as if S2 may be broken as this shows a redLED whilst S1 shows a green LED. I presume the unit would not calibrate if it sensed one relay was dead?
i’d just like to know whether i need to replace this unit. i bought it so long ago that it’s outside of warranty ( though unused up to now i might add).
Thanks,
Chris
