With many wifi enabled devices about.
Anyone  able to help out? Trying to use the HCL to POST or GET in a virtual device. Obviously a scene we cant do.
/xxxxxxxxxxxxxxxxxxxxxx
I am too lazy to read the manual.
Edited by Strydom
10 answers to this question
    SOLVED (Not secure and slow but works). Using wireshark to Debug, as the HCL has no debug . Its a start.
    Name : Test to IFTTT
    Room: Unassigned
    IP:maker.ifttt.com
    Port:80
    Button Trigger:
    GET /trigger/YOUR TRIGGER HERE/with/key/YOUR KEY HEREXXXXXXXXXXXXXXXXXX HTTP/1.1
    Host: maker.ifttt.com
    The trick, is after the Line  "Host: maker.ifttt.com", hit enter twice!  /n/n
    Any One?
    String
    GET /YamahaExtendedControl/v1/main/setPower?power=on HTTP/1.10x0D0x0A0x0D0x0A
    LUA
    local thisdevice = fibaro:getSelfId()
    local ip = fibaro:getValue(thisdevice, 'IPAddress')
    local port = fibaro:getValue(thisdevice, 'TCPPort')
    local httpSession = Net.FHttp(ip, port)
    response, status, errorCode = httpSession:GET("
    Not sure if this will help
    I have read the manual, not much to it.
    I don't think the HCL is capable of it.
    what i'm trying is
    GET /trigger/test_light_on/with/key/xxxxxxxxxxxxxxxXXXXXXxxxxXXXXxxxxXXXXX
    HTTP/1.1
    I know the HC2 works with this method. Is there another way? Bearing in mind that LUA code is a no no on the HCL.
    ADMIN is the HCl capable of this sort of thing?
    Your great scenes wont work with the HCL
    On 31.7.2018 at 18:10, Strydom said:
    Gelöst (nicht sicher und langsam, aber funktioniert). Verwenden von Wireshark zum Debuggen, da die HCL kein Debugging hat. Es ist ein Anfang.
    Name: Test nach IFTTT
    Raum: Nicht zugewiesen
    IP: maker.ifttt.com
    Hafen: 80
    Tastentrigger:
    GET / trigger / YOUR TRIGGER HERE / mit / key / YOUR KEY HEREXXXXXXXXXXXXXXXXXX HTTP / 1.1
    Der Trick ist nach der Zeile " Host: maker.ifttt.com ", drücken Sie zweimal die Eingabetaste! / n / n
    Was bedeuten " / n / n   ?
    Hello, now I also have the need a http command with the HCL off.
    http://192.168.178.53/plugins/sonos4lox/index.php?zone=wohnzimmer&action=start
    how did I implement this in the virtual module? Have already tried a lot. The command I only need to send as url in a browser. How does it work with GET in the virtual module?
    If someone is still interested. There is solution, that worked for me.
    You need to used
    IP Address and TCP Port of virtual device have to be fulfilled like below.
    Here is example of what should be inside button of virtual device. What is also important -  Wait for device response have to be checked.
    Edited by SmarterHOME
    HI
    I've a problem.
    I created a virtual button for my ifttt trigger:
    Port: 80
    With this string:
    GET /trigger/MYTRIGGER/with/key/MYKEY HTTP/1.10x0D0x0A0x0D0x0A
    But it doesn't work.
    If I run the complete URL on my browser, the trigger is fired and it's ok.
    Were I wrong?
