markymm
KeyFob problem - Cant change and save the parameters
Hello
I can’t activate additional functions in my KeyFob f.e. triangle button double click. This function changed its status to no active and it is showing action disabled, edit parameter 24. The problem is that I cannot change it because system doesn't save this value. The configuration menu behaves similar in other areas (it doesn't save new values of the parameters) Can someone help to resolve this issue?
/monthly_2018_07/image.png.b46363e6e73ce8eb91cf44f86efeaed5.png" />
Edited by markymm
Share this post
Link to post
Hi @markymm,
you are aware that you have to wake up the device after changing the parameters?
Share this post
Link to post
  • Thank you for help!  The parameter changes are memorized when I confirm my setting using KeyFob wakeup (I press O and + at the same time) i
    Share this post
    Link to post
