namboy1 0 Share Posted September 14, 2018 My HC2 was running fine for serveral weeks on ver. 5.10. Yesterday I noticed, that I I can'nt connect using my Phone. I checked from my PC - same behavior. Internal Error! I than switched off the HC2 using the button at the back. Wait for a minute and switched it back on. Now I getting "Starting Services". I left it now for couple of hours. No change! I did switch it off and on aggain, but the HC2 is not accessable anymore. I did not made any changes to the HC2, I also did not add any devicves. What can I do to gain access and control again. It's quite urgent thx & regards Rolf Quote Link to post Share on other sites
0 namboy1 0 Author Share Posted September 14, 2018 I just tried to recover the HC2, with the automatic option. Same behavior. I than tried to recover from backup file. It told me the Backup file is corrupt Urgently help needed .... Quote Link to post Share on other sites
0 sir_horn 2 Share Posted October 1, 2018 I’m having the exakt same issue. Did you find a solution? Quote Link to post Share on other sites
0 namboy1 0 Author Share Posted October 2, 2018 If you have made a backup, you can reboot the HC2 into recovery mode, delete all data (the rightmost recovery option), and then restore the last backup after the 4.510 has been reinstalled. I used the same backup file as tried before with the automatic option - where I got the message, the backup file is corrupt. Quote Link to post Share on other sites
0 T.Konopka 1 Share Posted October 2, 2018 @namboy1 , did the restoration of the backup help in your case? Or did you get the error that the file is corrupt and that's all? Quote Link to post Share on other sites
0 BOT 0 Share Posted October 2, 2018 The topic has been moved from "Update 4.510" to "Home Center 2". Temat został przeniesiony z "Update 4.510" do "Home Center 2". Quote Link to post Share on other sites
0 namboy1 0 Author Share Posted October 2, 2018 It did help - everthing worked afterwards again! Quote Link to post Share on other sites
namboy1 0
It's quite urgent
thx & regards
Rolf
Link to post
6 answers to this question
