play3man 5
We have few light switch installed with Fibaro and one of them was Double Relay Switch (old model of Double Switch 2 with In and L). We bought a Double Switch 2 to change this relay because we wanted to measure power consumption.
Double Relay Switch was/is installed on one Double (mechanical) switch to control two separate lights. One light can be controlled only from this switch, the second one can be controlled from more places / switches.
With Double Relay Switch there was no problem, we installed it at the first attempt and everything was working as it should. After we bought the Double Switch 2, we just replaced the Double Relay Switch, every single wire we connected to the same input/output and turn the power supply on - and here magic happens. The left mechanical switch (S2) works fine, the right does nothing (S1). Absolutely nothing, no click sound in Fibaro Double Switch 2, no lights. Then I tried to turn the light on with the app through Fibaro - at it works for both.
OK, I tried to switch the S1 and S2 wire to check if one of the Fibaro Double Switch relays is false. But, another magic, the left mechanical switch still works (S1) but the right does nothing anyway (S2). From this it looks like there is some problem with the mechanical switch. So i took one of the wires for light and put it directly to the right mechanical switch to bypass Fibaro - vuala, the right mechanical switch does work and the light is switching on and off without any problems.
At this moment I was feeling helpless and just uninstalled the new Double Switch 2, took the old Double Relay Switch and installed it back - it works as it should!
What the heck is happening here. At the last, i just tried to install Double Switch 2 to a different double mechanical switch - different circuit. It took me five minutes to install everything the same way as with the previous and in this it is working!
OMG I really don't know what I'm doing wrong so the Double Switch 2 is not working in place where Relay Switch is working without any problems! Any ideas please? Thank you!
Edited by play3man8 answers to this question
