Power Surge error dimmer 2
felix_oslo
I have one Dimmer 2 in a 2 wire connection. The load is 6 x 12v halogen spots, 35 watt. The load should not be to much as far as I can see, but I get Power Surge error  all the time. The transformer is a standard transistor type.
I have tested the following without any luck:
1. Adjusted max and min parameter 1 and 2 to minimum 20 and max 70%
2. Forced several autosync #13
3. Then manually forced the dimmer by parameter #30 to Trailing Edge mode, and tested leading edge as well, no changes
4. Even tried to change L and N to the "wrong" position just to verify
5. Fully reset the device
Firmware is the latest, I think it's V3.5.
Does anyone have any suggestions?
Thomas
Edited by felix_oslo
6 answers to this question
@felix_oslo most transformers can not be "dimmed"
are you sure you can use a dimmer with this transformer?
if so, try to connect the 3rd wire on the dimmer (neutral)
  • Yes, I'm sure, they have worked fine with a standard ELKO dimmer before, and the supplier confirms that that is OK
  • The dimmer should work fine without "3-wire" connection, and to do so, I need to do a whole lot of work in the walls. It's not any subject to do so since I need to take down walls.
    Dear Felix,
    Just try to test is from a neutral. pin from a wall outlet near the dimmer
  • Sure I can, but if that helps, it won't help my problem. I don't think the load is to heavy, all the cables has been tested to the spots, without any errors.
