Hi all,
I see that some users have downloaded
script and I think it could be a good idea to share our data and know-how to optimize our Z-wave performance.
In my case I have manage to reduce Z-wave traffic from average of event per 1.7 sec. to 4.8 sec (24 hours monitoring, 78 physical devices, 382 IDs), but I don't know if this is a good number. It will be interesting if anyone could share  an average of his system. That way we can compare and might be to achieve the right number and stable performance which may be could prevent Z-wave freeze in the future.
I think average of Z-wave traffic somehow depends on number of the devices in the system and again I believe we need team work to find correct formula for that.
Few users have shared with me that they have found devices, which "bombarding" the traffic with unnecessary reports and they fixed the issue.
It could be very helpful to all of us to share our solutions and fixes...  we all can learn from others
If you think it could violate your privacy,   please ignore this message...
Thank you
I meant including graph, like the data from cag014
1 hour ago, petergebruers said:
You mean output of Lua script? Save as text file on your computer then click on "choose files" at the bottom of your new post to upload and insert that file.
I meant including graph with the format like shown in the debug windows of the z-wave monitor scene.
    To post here the data from Z-wave monitor, you need to take a snapshot of the debug window...
    You can use Windows' built-in Snipping Tool for that...
    Edited by cag014
    On 12/27/2018 at 12:15 AM, cag014 said:
    Hi all,
    Thank you
    Hi
    Hi
    I am not sure, do I need to change the following in the monitor? You mention to use an "_" but i see that only before "531" in the code... and what do these scene/device numbers represent in the result?
    dev2review={false,"|470|804"}.
    userDev={false,"|504|_531|"}
    Edited by twannieguitar
    You need to change all ID numbers to your IDs. It's just an example.
    Use underscore "_" if it is scene ID. In the system scene and device could have same ID number, so assign underscore to distinguish between them.
    This numbers used to review the Z-wave of specific IDs.
    dev2review={false,"|470|804|"}.  - first variable is true or false (display or not the data chart). After that all numbers are device IDs to review actual readings of the devices (like power, energy, Lux, temperature. Devices with results of true/false won't be displayed). You can define devices only (no scenes allowed)
    userDev={false,"|504|_531|"}  - same, first variable is true or false (display or not the data chart). After that all numbers of device or scene ID to review number of Z wave events of each ID. Here you need to use "_" for scene IDs.
    For example:
    Let's assume that you have wall plug with ID=600, temperature sensor ID=670. Scene ID=600 and another scene ID=200
    Now to review actual results of wall plug and temperature sensor define as follow:
    dev2review={true,"|600|670|"} You will see two charts for each device of actual results on timeline.
    userDev={true,"|600|_600|"}  you will see one chart with two diagrams (device ID=600 and scene ID=600) of Z wave event numbers on timeline
    See below example of Greenwave power node actual readings... this device is bombarding the Z wave traffic..
    Looks much better, isn't?
    This is a real example of my system. Without Zwave monitor I didn't have any tool to identify this heavy traffic.
    Quite happy with the results so far, moved from 0.9S to 5.2S by changing some energy measurement values
    [DEBUG] 06:22:25Z-wave Viewer v2.2
    id
    total #
    total %
    value
    power
    batteryLevel
    energy
    targetLevel
    color
    mode
    sceneActivation
    unit
    Device description
    771
    1603
    34.5%
    401
    401
    801
    Netwerk & Domotica @ Hal
    70
    1152
    24.8%
    668
    47
    437
    Mediahoek @ Woonkamer
    475
    405
    8.7%
    162
    243
    Verw Vloer presets @ Vloer Badkamer
    772
    398
    8.6%
    398
    Netspanning @ Hal
    241
    234
    5.1%
    219
    7
    8
    Laptop @ Woonkamer
    76
    93
    2%
    83
    6
    4
    Verwarmingsketel @ Voorzolder
    131
    81
    1.8%
    57
    7
    17
    Vriezer @ Bijkeuken
    594
    79
    1.7%
    79
    Centrale Afzuiging @ Voorzolder
    584
    75
    1.7%
    75
    Stopcontact A-deur @ Bijkeuken
    74
    62
    1.4%
    62
    Wasmachine @ Bijkeuken
    224
    59
    1.3%
    59
    Temp Schuur @ Schuur
    623
    50
    1.1%
    48
    2
    Lux Voor @ Voortuin
    62
    34
    0.8%
    22
    4
    8
    Koelkast @ Keuken
    498
    31
    0.7%
    31
    Temp 1 Keuken @ Keuken
    322
    30
    0.7%
    30
    Temp Hal plafond @ Hal
    32
    27
    0.6%
    27
    Temp Slaapkamer @ Slaapkamer
    244
    25
    0.6%
    8
    16
    1
    Lamp Salontafel @ Woonkamer
    613
    18
    0.4%
    6
    12
    Spots Keuken @ Keuken
    105
    18
    0.4%
    18
    Temp Werkbank @ Bijkeuken
    447
    16
    0.4%
    16
    Sensor 2 Keuken @ Keuken
    100
    16
    0.4%
    8
    8
    Lamp Hal @ Hal
    476
    13
    0.3%
    13
    Temp Vloer Badkamer @ Vloer Badkamer
    518
    12
    0.3%
    6
    6
    Lamp Nis @ Keuken
    565
    12
    0.3%
    4
    8
    Spots Badamer @ Badkamer
    622
    11
    0.3%
    9
    2
    Temp Voorraam @ Voortuin
    789
    9
    0.2%
    3
    3
    3
    Waterkoker @ Keuken
    86
    9
    0.2%
    9
    Minimote Zwart @ Controllers
    497
    8
    0.2%
    8
    Sensor 1 Keuken @ Keuken
    321
    8
    0.2%
    8
    Sensor Hal @ Hal
    53
    6
    0.2%
    2
    4
    Lamp Slaapkamer @ Slaapkamer
    449
    6
    0.2%
    6
    Lux 2 Keuken @ Keuken
    323
    6
    0.2%
    6
    Lux Hal @ Hal
    114
    5
    0.2%
    5
    Temp Bijkeuken @ Bijkeuken
    499
    5
    0.2%
    5
    Lux 1 Keuken @ Keuken
    168
    5
    0.2%
    5
    Temp Plafond Keuken @ Keuken
    124
    4
    0.1%
    4
    Sensor Badkamer @ Badkamer
    126
    4
    0.1%
    4
    Lux Badkamer @ Badkamer
    298
    3
    0.1%
    3
    Temp Zolder @ Zolderkamer
    621
    2
    0.1%
    2
    Sensor Voor @ Voortuin
    33
    2
    0.1%
    2
    Lux Slaapkamer @ Slaapkamer
    294
    2
    0.1%
    1
    1
    Thermostaat Badkamer @ Badkamer
    641
    2
    0.1%
    1
    1
    Lamp Afzuigkap @ Keuken
    423
    2
    0.1%
    1
    1
    Thermostaat Bijkeuke @ Bijkeuken
    327
    2
    0.1%
    2
    Temp Achtertuin 2mtr @ Achtertuin
    134
    2
    0.1%
    2
    Temp Afdak @ Afdak
    50
    2
    0.1%
    2
    WS Eettafel @ Controllers
    31
    2
    0.1%
    2
    Sensor Slaapkamer @ Slaapkamer
    125
    2
    0.1%
    2
    Temp Badkamer @ Badkamer
    329
    1
    0.1%
    1
    325.0.3 @ Achtertuin
    500
    1
    0.1%
    1
    496.0.3 @ Keuken
    217
    1
    0.1%
    1
    Temp Hal @ Hal
    60
    1
    0.1%
    1
    Droger @ Bijkeuken
    448
    1
    0.1%
    1
    Temp 2 Keuken @ Keuken
    267
    1
    0.1%
    1
    Temp Vloer Keuken @ Keuken
    34
    1
    0.1%
    1
    30.0.3 @ Slaapkamer
    Thanks for the info cag04... great tool to identify!!
    Hi cag04
    I suddenly get this error when running the scene after restoring a backup
    [DEBUG] 04:20:05: 2019-03-02 04:20:05.042977 [ fatal] Unknown exception: /usr/share/lua/5.2/json/decode/util.lua:35: unexpected character @ character: 1 0:1 [] line:
    [DEBUG] 04:20:05:
    any idea what is happening?
    Yes, your global variable is corrupted or blank/empty (usually happens when the system is restarted/rebooted)
    Please delete the global variable and run Zwave Monitor, it will create again correct global variable.
    The global variable name is zwave_your_scene_ID
    I've fixed this in next release....
    Edited by cag014
    Thank you cag014!
    My results are not bad at all. I was expecting worse ;-)
    Of course I'm going to look at a few devices which are reporting to many times (in my opinion).
    Elapsed time = 24:00:14 [ Apr 14 20:40 - Apr 15 20:41 ]
    Sample log rate = 1 minutes. Total samples 1441
    Z-wave events = 8144 on 118 devices.
    Average traffic = 10.7 sec.
    Z-traffic range = 1.4 - 90 sec.
    Repeat / Report = 3596(44.1%) on 105 devices.
    id total # total % rpt value timestamp targetLevel batteryLevel dead deadReason power energy currentProgram currentProgramID color lastColorSet brightness mode tamper sceneActivation Device description
    67 1504 18.5% 1438                           66     Actuator @ Attic
    230 996 12.3% 18             975 3                 Smartwatch C @ Master bedroom
    167 605 7.5% 55 11           539                   Spots Badkamer @ Bathroom
    319 226 2.8%   226                               6in1 @ Kitchen
    201 202 2.5% 3 199                               Lux Badkamer @ Bathroom
    318 201 2.5%   201                               6in1 @ Kitchen
    317 189 2.4%   189                               6in1 @ Kitchen
    91 180 2.3% 5 174     1                         Licht Gang @ Hallway
    64 176 2.2% 6 170                               Beweging Lux @ Living
    372 174 2.2%               172 2                 Wasmachine @ Attic
    132 173 2.2% 24 24           74 1 4 4 16 10 16       LED Keuken @ Kitchen
    374 166 2.1%   166                               Wasmachine @ Attic
    96 161 2% 6 155                               Beweging Overloop @ Overloop
    73 139 1.8% 63 57     19                         Temp Woonkamer @ Living
    18 135 1.7% 12 2           119 2                 TV @ Living
    50 111 1.4% 85 2           23 1                 Smartphone A @ Master bedroom
    62 108 1.4% 7 101                               Beweging Woonkamer @ Living
    177 96 1.2% 37 59                               Luchtvochtigheid @ Bathroom
    72 95 1.2% 64 4 4 4 19                         Thermostaat @ Living
    89 89 1.1% 5 81     1                     2   Motion hallway @ Hallway
    176 82 1.1% 37 45                               Temp Badkamer @ Bathroom
    94 82 1.1% 6 76                               Beweging Overloop @ Overloop
    350 79 1% 79                                 KerstRaam @ Living
    223 78 1% 39 39                               Temp Slaapkamer1 @ Nursery
    52 77 1% 77                                 Deken A @ Master bedroom
    191 76 1% 29 15               2 2 12 6 10       Led Meterkast @ Meterkast
    54 74 1% 74                                 LaptopC @ Living
    82 67 0.9% 31 13                   10 5 8       Led Slaapkamer @ Master bedroom
    158 64 0.8% 64                                 CO Zolder @ Attic
    168 55 0.7% 55                                 160.1 @ unassigned
    169 55 0.7% 55                                 160.2 @ unassigned
    199 53 0.7% 3 48                           2   Beweging Badkamer @ Bathroom
    231 44 0.6% 18 2           23 1                 Smartphone C @ Master bedroom
    209 43 0.6% 34 4           5                   Dressoir Lamp @ Living
    316 43 0.6%   43                               6in1 @ Kitchen
    17 42 0.6% 12             21 9                 Horizon @ Living
    228 40 0.5% 18             11 11                 Wekker C @ Master bedroom
    139 39 0.5% 30 9                               Lamp Gang @ Hallway
    222 38 0.5% 38                                 220.1 @ unassigned
    221 38 0.5% 38                                 Dakterrasdeur @ Nursery
    178 37 0.5% 37                                 Everspring @ Bathroom
    179 37 0.5% 37                                 Everspring @ Bathroom
    335 35 0.5% 4 31                               Rookmelder Baby Temp @ Nursery
    16 35 0.5% 12             7 16                 Home Cinema @ Living
    83 31 0.4% 31                                 81.1 @ unassigned
    84 31 0.4% 31                                 81.2 @ unassigned
    87 31 0.4% 31                                 81.5 @ unassigned
    86 31 0.4% 31                                 81.4 @ unassigned
    85 31 0.4% 31                                 81.3 @ unassigned
    141 30 0.4% 30                                 Buitenlamp voor @ Driveway
    140 30 0.4% 30                                 138.1 @ unassigned
    294 29 0.4% 29                                 292.1 @ unassigned
    194 29 0.4% 29                                 118.3 @ unassigned
    192 29 0.4% 29                                 118.1 @ unassigned
    196 29 0.4% 29                                 118.5 @ unassigned
    195 29 0.4% 29                                 118.4 @ unassigned
    295 29 0.4% 29                                 BelGong @ Hallway
    193 29 0.4% 29                                 118.2 @ unassigned
    293 29 0.4% 29                                 Doorbell @ Driveway
    233 28 0.4% 18             2 8                 Bed Corné @ Master bedroom
    40 28 0.4% 28                                 Beschikbaar @ unassigned
    135 24 0.3% 24                                 LED Keuken @ Kitchen
    133 24 0.3% 24                                 LED Keuken @ Kitchen
    76 24 0.3%   24                               RM Temp @ Hallway
    136 24 0.3% 24                                 LED Keuken @ Kitchen
    134 24 0.3% 24                                 LED Keuken @ Kitchen
    137 24 0.3% 24                                 LED Keuken @ Kitchen
    19 20 0.3% 12 2           4 2                 Subwoofer @ Living
    171 20 0.3% 16 4                               Ventilation @ Bathroom
    373 20 0.3%   20                               Wasmachine @ Attic
    232 18 0.3% 18                                 Deken C @ Master bedroom
    229 18 0.3% 18                                 Lamp C @ Master bedroom
    227 18 0.3% 18                                 226.0 @ unassigned
    200 17 0.3% 3 14                               Beweging Temp @ Bathroom
    361 17 0.3% 1 16                               Rookmelder temp @ Overloop
    63 17 0.3% 6 11                               Beweging Temp @ Living
    172 16 0.2% 16                                 170.1 @ unassigned
    173 16 0.2% 16                                 170.2 @ unassigned
    57 15 0.2% 7 8                               RM Temp Woonkamer @ Living
    30 14 0.2% 14                                 Balkondeur @ Master bedroom
    12 13 0.2% 7 6                               Frontdoor @ Hallway
    20 12 0.2% 12                                 Greenwave6 @ Living
    14 12 0.2% 12                                 Greenwave @ Living
    127 12 0.2% 5 7                               Temp Slaapkamer CA @ Master bedroom
    15 12 0.2% 12                                 Raspberry Pi @ Living
    26 11 0.2% 11                                 Raam Woonkamer @ Living
    95 10 0.2% 6 4                               Temp Overloop @ Overloop
    225 10 0.2% 10                                 Raam MB @ Master bedroom
    28 9 0.2% 9                                 Tuindeuren @ Living
    339 9 0.2% 4 5                               Rookmelder MB Temp @ Master bedroom
    125 9 0.2% 6 3                               Slaapkamerdeur MB @ Master bedroom
    299 8 0.1% 3 5                               Rookmelder Temp @ Attic
    90 8 0.1% 5 2     1                         Temp gang @ Hallway
    97 7 0.1% 7                                 93.0.3 @ unassigned
    56 7 0.1% 7                                 Rookmelder Woonkamer @ Living
    58 7 0.1% 7                                 Rookmelder Woonkamer @ Living
    65 6 0.1% 6                                 61.0.3 @ unassigned
    126 5 0.1% 5                                 114.1 @ unassigned
    92 5 0.1% 4       1                         88.0.3 @ unassigned
    338 4 0.1% 4                                 Rookmelder MB @ Master bedroom
    343 4 0.1%           2 2                     Dakraam @ Attic
    380 4 0.1% 4                                 Keukendeur @ Kitchen
    333 4 0.1% 4                                 Rookmelder Babykamer @ Nursery
    346 4 0.1% 4                                 Lekkage Zolder @ Attic
    334 4 0.1% 4                                 Rookmelder Babykamer @ Nursery
    381 4 0.1% 4                                 Keukendeur @ Kitchen
    347 4 0.1%           2 2                     Dakraam @ Attic
    342 4 0.1%           2 2                     Dakraam @ Attic
    337 4 0.1% 4                                 Rookmelder MB @ Master bedroom
    345 4 0.1% 4                                 Lekkage zolder @ Attic
    202 3 0.1% 3                                 198.0.3 @ unassigned
    298 3 0.1% 3                                 Rookmelder Zolder @ Attic
    297 3 0.1% 3                                 Rookmelder Zolder @ Attic
    366 2 0.1%   2                               Belknop Keypad @ Meterkast
    24 2 0.1% 2                                 Sirene @ Meterkast
    79 1 0.1%                                 1 Minimote @ Master bedroom
    359 1 0.1% 1                                 Rookmelder overloop @ Overloop
    360 1 0.1% 1                                 Rookmelder overloop @ Overloop
    Edited by Cafun
    The result of
    is extremely high (should be less  than 10%).
    Please check deviceID 67,looks like you send to many same commands. For example if the device is ON, your code continue to send turnOn command.
    It could be that you're using block scene to activate this device, in this case I suggest to use LUA code and to verify the device state before sending command.
    My guess that some motion sensor triggering your scene to control this device.
    Thanks for your reply.
    Wel no actually. deviceID 67 is my heating (Horstmann SSR303 & SRT321). It indeed turns on/off a lot. Next week my house will be isolated, so then it should be less ;-)
    In all my code I check if something is on already and it should not send the turnOn command again. But I'm gonna double check my code (I only use lua).
    Thanks again.
    /monthly_2019_05/Untitled1.png.5bb2c755b6d1841e29ca93544c7530f3.png" alt="Untitled1.png.5bb2c755b6d1841e29ca93544c7530f3.png" />An example of how the patient's heart stopped
    Instant death.
    Hello. In order to reduce the load on the HC2, I added NSL, transferred to it energy counters and temperature sensors from the heat pump.
    In your scanner, these data are combined, the data from the HC2 and NSL. But this does not mean that it is a load on one Z -Wave chip?
    NSL = HCL
    translator :-D
    I have run Z wave monitor on my system, and here are the results. I am a real novice so don't know if the issues or crashing is related this this performance
    I look forward to feedback
    Looks like you Z-traffic is not overloaded... but you have Repeated/Reported Z-traffic over 50%!!!
    Looks like you send too many same commands to devices...
    Please check status of the device before sending command.
    Interesting, how many Z-wave crashes you have ? I mean what is the crashes frequency ( once per day, week, month...)
    The system seems to crash about every 2 weeks. Sometimes once or twice within a couple of days and then it settles down again.
    Can this be avoided? Reduce all this traffic?
    Are you using block scenes?
    I will be honest to say that I did not write my system I paid a professional to do it, but due to having problems for over a year I decided to try and take matters into my own hands.
    I don't know what a block scene is and also how to use them?
