After configuring a new house using the HC2, I have a few frustrations related to the inclusion process for new devices (Add Device):
When assigning a device to a room, it would be nice to be able to assign the main device only, and have all the sub-devices/slaves follow. Having to do the room assignment on each one is time consuming (in one of my cases, a Z-TRM2 thermostat, there are 11 sub-devices per unit!). Is there a smarter way?
When I check "NWI" in the Add Device panel, or make any other change to the three inclusion options, the "Save warning" (an exclamation mark) appears to the right. The save button does nothing, however, and there is no other save possibility. When inclusion is complete, any attempt to exit gives a warning that a "save" is missing and that data may be lost. I think there is a bug in this particular panel. Either the warning is unneeded, or the save button should be activated to store the choice of options. Have I missed something?
Why is there a button in the Advanced section to "download template", when there is no way to install what I download? I know the procedure is to forward the template to Fibaro Support (and keep expectations low for any follow-up), but it seems strange to handle this inside the configuration panel when the template cannot be configured by the user.
knuth 26
Link to post
