P Jonak 0
Hi Fibaro experts,
I have been using my fibaro setup for a couple of years with mixed success. Some things work quite well and some, well not so well. Feels at times as if the software really isn't tested before it is released which is unfortunate. Anyway I still like what it can do so trying to live with the problem it causes.
However, this problem really annoys me and must be fixable somehow so hoping someone out there has a clever answer for it.
One of the setups I have today:
1 fibaro dimmer 2 in the hallway
1 fibaro dimmer 2 in the kitchen
The dimmer in the kitchen is associated with the hallway dimmer so that S2 is able to control the light in the hallway. This works fine as long as I always control it from the kitchen. So if I press once the hallway lights up and if i press another time the hallway goes dark, just as expected. However, If I press once on S2 in the kitchen and then switch it off in the hallway (with the wall switch i have there) the control in the kitchen looses sync why i need to press it twice to light it up again.
So what happens is that the kitchen dimmer works fine as long as I don't use the wall switch connected to the hallway dimmer. If I do then the dimmer in the kitchen
Case 1:
1. activate S2 in Kitchen > Hallway lights up.
2. activate S2 in kitchen again > Hallway goes dark
Case 2:
2. activate S1 in hallway > Hallway goes dark
3. activate S2 in kitchen again > Nothing happens (reason is because the kitchen dimmer tries to shut down the hallway light as it wasn't aware that i already killed the light via the hallway dimmer)
4. if i then press S2 in the kitchen again the light in the hallway lights up again.
A small thing but oh so irritating. There must be something I am missing as I have the same functionality in my walk in closet and my bedroom. However, with the difference that i there have a dimmer 2 in the bedroom and a dimmer 1 in the walk in closet. For some reason these two devices sync perfectly and work seamlessly together.
Anyone out there that has the same setup? Have you been able to solve it?
/Peter
Edited by P Jonak6 answers to this question
