SmartHomeEddy 1,008
I want to connect my normal alarm with my Fibaro Homecenter 2. I think the Smart Implant can do the trick and I have bought some 12 volt relais to support the Smart Implant because the Smart Implant can’t switch high outputs and is restricted tot 0 - 10 volt. The relais can switch a sabotage loop (normally closed), so the normal alarm will be breached.
The functions I first want to achieve are:
If my Fibaro Homecenter detects alarm, my normal alarm will be breached and the normal sirene and light signals turn on (etcetera)
If my normal alarm is breached, my Fibaro Homecenter will send push messages (etcetera)
And in the future I want to:
Turn my normal alarm on and off with my Fibaro Homecenter
I can give power to the Smart Implant (P red / GND blue) from my normal alarm
The relais can also be given power from the normal alarm. The relais has an input with requires a 12 volt signal.
Question: How can I give the relais the 12 volt signal with de Smart Implant?
Diagram Smart Implant:
Relais:
/monthly_2019_03/relais.png.017090d9d491823e2269ec70e69a4d7b.png" alt="relais.png.017090d9d491823e2269ec70e69a4d7b.png" />5 answers to this question
