How can I activate the roller shutter 2 to open when the heat detection in the smoke sensor is active?
parameter 33 in the roller shutter is set to 'Open blind'
parameter 2 in the smoke sensor is set to 2
parameter 30 in the smoke sensor I set to low value in order to tigger temperature alarm, but the Roller shutter won't open.
Heat detection is been triggered
Is this the correct way to do?
thx
Rik
i do it wit a script for al kinds of alarm (smoke, water, fire etc.....)
    Yes, that's a possibility,  but I hoped it would work as I described, so no scripting necessary.
    I just don't know if it is designed to work like this. Anyone?
    Suppose you don't have a HC2 but HCL, what to do then. HCL probably with block scenes.
    Fibaro Support proposed to do a soft reconfiguration. That did not help. I now wonder if it will work at all.
    Has nobody tried it?
    Edited by Rikbast
