HC2 Failure Recovery mode
Good day,
Is anybody facing the same problem like me? I will appreciate if you have any suggestion on this topic.
I am trying to recover my HC2, but always I reach the following stage: black screen with text "Fibaro Home Center Recovery" and nothing else that I can do....
My IP is set by default to 192.168.81.1
Link to post
5 answers to this question
Hi, read the manual recovery!
Set IP of computer see picture
connect pc with cable on HC2
change in HC2 to IP adres fit in your local network
Succes
Link to post
Thanks for the advise, but apparently this is something that needs to be done by Fibaro support!
I tried everything possible and described in the manuals and internet, but nowhere I found such text on black screen.
I hope that soon I will have a success.... hopefully
Link to post
Did you finally got the recovery panel? I am hitting the same black screen and can't get past it.
If you have fixed it, please advise how you did it so I can give that a try. Thanks!
Link to post
I sent the HC2 for repair in Poland. They found out that the motherboard was damaged. I few months later they send it back... After multiple attempts to contact the repair team. However, their Telephone support is really good. So do not waste time and call them.
Another thing that we found out is ... if the BIOS battery is low, HC2 is booting and restarting.... the blue lights are in start-up mode, but then restart again and again. This is because of the BIOS battery.
I hope I was helpful
Link to post
Thanks for the feedback and I hope I won't have to send it for repair as 70% of my home is Fibaro dependent. I can ping my HC so that gives me hope that it's reachable...
Were you able to ping or access it through terminal before finally sending it to Poland?
I'll be calling them tomorrow as they don't work during the weekend (which is something I'll suggest because people homes are depending on their devices 24x7).
Thanks so much!
Link to post
