amatt 5
I have a smart switch 6 made by AEOTEC. It took several attempts to add it correctly in HC2. Once it did it added the switch and a Volt and Amp meter. The Amp and Volts work just fine but switching the switch on and off does nothing. to turn it on and off I have to press the action button on the switch. even if I do that the status does not change on HC2. Can someone explain what is wrong? Fibaro bug? I know there has been some issues in the latest versions with parameters but I don't see why it would cause this issue.
*Note when I added it on my first several attempts it would say not configured but. was able to turn the device on and off successfully (so I know it does work).
this did the same thing on 4.540 and 4.541 beta.
6 answers to this question
