Azkikr 1
I have created different scenes in the block scene editor. These are all working except for the one that should do the following:
1. When I arm the alarm, the door sensor is armed.
2. When I open the door it should give me 10 seconds before the alarm goes off.
3. If I disarm the alarm, therefore disarm the door sensor within 10 seconds the alarm should not go off.
This all works fine with a minor detail: if I shut the door within 10 seconds the alarm does not go off, while it should go off unless I have disarmed the alarm.
I have tried the following block scene:
/monthly_2019_06/image.png.345f7cde98245097eee195f4a34bab29.png" alt="image.png.345f7cde98245097eee195f4a34bab29.png" />First I tried stating at the device that if it's armed and breached it should trigger and I put a 10 second delay at the end. That did not work.
Then I tried the above method checking if the door is device is triggered while armed and breached AND if after 10 seconds the device is NOT disarmed.
By the way I also tried the statement if after 10 seconds it IS armed. Both with the same result: If I close the door quickly enough, I'm inside and the alarm is not triggered.
Then I thought that maybe it just does not work that well within the block scenes. So I transfered it to LUA (automatic method by Fibaro). The LUA code I get, looks horrendous though. I'm not a developer, but this does not look as very well written code to me.
So here I am, with the big question to you out there: is there anyone who has this working and what code do you have?
4 answers to this question
