I have a HC2 on version 4.551
Been adding Qubino PWM thermostats and struggling to get them to configure properly
The second one I added has added correctly and works perfectly (can set a temperature and the temp sensor works and is accurate)
/monthly_2019_09/image.png.52f86a4cc17aad759d1c72a96b32408b.png" />
All others have been adding as below
No temperature sensor (i have checked its been plugged in) and temperature resets itself to 4oC
If anyone knows how I can change the configuration or copy the settings of the one that has worked i would be glad!
Warwick
Hi I have installed 6 Pce and and 2 worked perfect when i made the inclusion but the other i added , removed and factotory reset many times
keep it up eventually they will include
Hello!
Has anyone tried this module on the HC3?
Thanks!
