Qubino 3-Phase Smart Meter - not working with HC2
PAL_HC2
The Qubino 3-Phase Smart Meter can operate an external contactor if certains parameters
are set - this is a very smart solution for controlling that you can cut power in case of to
high current (power) consumption.
BUT,
The setup method described is based on settng certain parameters in the Smart Meter
while included (no 7=3 and no 100=11), then exclude the unit and when included again
it will be noticed that there is an output activiated.
The problem is that HC2 over writes alla parameters to default while including
the unit making the idea off Smart Meter useless
Advicew please
8 answers to this question
  • Since my posting I have given up the usage of the IR-controlled contactor and applied a classic contactor that is controlled by a Fibaro relay module.
    BUT, the problem does not end there as there are no commands in the scene scripting (by graphical elements) that can control the power usage.
    I am at this stage rather pissed by the "compatability" between modules on Z-Wave.
    If someone has experience from this unit in LUA I would love to get enligthened!
    I even double-checked with the distributor in Sweden before buying and they swore to the compatibility.
    If I have to buy an extra switch an a DIN case to house it, the cost for the wanted functionality goes up by 100 Euro approx.
    No good at all.
    Update:
    After a long conversation with the support at Qubino and Fibaro about what might be the problem, here is the response I got from Fibaro:
    Quote
    Unfortunately in our system re-inclusion of the device as you have mentioned correctly resets the parameters.
    We’re aware of this issue and we’ve already forwarded it to our engineers, who are currently working on resolving it as soon as possible. I’m very sorry for the inconvenience it caused but I have to ask you for a little more patience.
    In the meantime, please try, after changing the parameters to use function “soft reconfiguration” or “reconfiguration” of the device when parameter is changed and see if that helped.
    At the moment i do not have any other solution that i can present to you.
    It remains to be seen if they will ever fix it.
    Edit: Have updgraded to 4.570. It still does not work.
    Edited by perjar
    Just upgraded to 4.580 and it still does not work.
    They have implemented a better template in the UI now so it is a lot easier to change the parameters. But the problem still remains,  that all parameters are reset to default when reincluded.
    On 11/15/2021 at 6:09 PM, Hakon said:
    Any updates?
    Can i use power consumption in a block scene?
    HC2 version 4.620.
    Not sure about the issue with the IR-controlled switch. I gave up on it.
    Regarding using the power consumption in a block scene: Yes it is possible. You can trigger on =,<,> etc
    And in Lua code you can fetch the power like so:
    power = fibaro:getValue(the_smart_meter_device_id, "power")
