Wiring connection between Smart implant, Motion sensor and Alarm system
Hi, I  have a FGBS-222 smart implant, Paradox NV5 motion sensor and a SP4000 paradox alarm control board attached to paradox K636 key pad. The problem is how do connect the wiring from the motion sensor to the smart implant and from the smart implant back to the alarm control board??
/monthly_2019_10/image.png.3eb47223bd9f128820190a69ad9618da.png" />
above it the NV5 motion sensor terminals.
Above is the terminal for the SP4000 alarm control board.
Last but not least the smart implant terminal.
Below is my wiring connection.
I am able to control the output of the fibaro smart implant from the fibaro home center lite however, the smart implant cannot detect the output of the motion sensor. Any suggestion to modify??
Aside question, is fibaro smart implant able to arm or disarm a alarm system??. Thank you.
As I understand you need to connect wires from motion sensor to smart implant input (IN1) and output (OUT1) connect to your alarm.
On your diagram looks like you did it correct.
Is it work for you?
You just need to set parameters in smart implant correctly (normally closed or open)
Edited by cag014
Are you able to adjust your alarm panel programming to get the implant to arm and disarm?
