I have a problem with IR Remotec ZXT-120 that when it operates with batteries it can't control the temperature of the AC, it only controls the AC mode.
Any ideas how to make it control the temperature.
Note: When it operates with the 5V DC power supply it can control the temperature.
thanks!
Do you use predefined IR code or learning by you? If predefined, did you test all code for your manufacturer and do soft reconfiguration of ZXT-120 after code changed?
Edited by drboss
