Showing results for tags 'air condition'.
Found 3 results
  1. I have a problem with IR Remotec ZXT-120 that when it operates with batteries it can't control the temperature of the AC, it only controls the AC mode. Any ideas how to make it control the temperature. Note: When it operates with the 5V DC power supply it can control the temperature. thanks!
  2. Hello all, Did anyone of you used the Carrier Furnace Plugin? If yes, can you help me with some steps on "how to"? I am trying to configure the Carrier Furnace for my air conditioners but it is not working. I have added the air conditioner in my Wireless Lan and I can control these using the provided Carrier App. When I am trying to find the air conditioners using the network configuration ip address search, it is showing me that there is no air conditioner available in my WLAN. I have tried also by adding directly the IP address that I can see by opening the WiFi Router settings, but it is still not finding it. Thank you in advance. Best Regards, Alex F.
  3. Hi everyone, I need help... so if anybody can give me a hand I will be very grateful. I have following hardware: Home Center Lite, Remotec ZXT-120 and Air condition unit. I am able to control AC through Fibaro app, everything is OK with that. I can remotely turn AC ON, OFF and select heating and temperature. Challenge: The AC unit accepts only 16 degrees as minimun heating value. The cabin is only used time to time and mostly it is unoccupied and temperature inside should be only 5 degrees. When arriving to cabin temperature should be increased to 21 degrees through Fibaro app. How this could be solved with HCL ? I can make following scenes 1. a block scene which will turn up AC to heat when temperature in cabin is below 5 degrees. 2. second block scene 2 which will turn off AC from heating when temperature is 7 degrees. 3. third block scene which will turn up AC to heat 21 degrees. But the second scene will then turn off the third scene. (loop) I really need help with this one...
