Hi!
I have had Netatmo plugin running flawless for 3 years.
2 Days ago, Fibaro suddenly stopped pulling the API.
When I select "get devices" from plugin, nothing happens.
If i try to deactivate and reactivate netatmo account (dev), nothing happens.
But if i restar the HC2, it will pull the correct vaues one time, then stops.
Anyone have a solution to this? Other than deleting plugin and readd it, cause i have alot of lua scenes based on the devices.
Best regards
Chris
5 answers to this question
    Found the answer.
    I have a rain module, and when i removed batteries for the winter. The HC2 could not pull anything anymore.
    Without much investigation, i think the plugin got stuck when trying to read the last entries in API. Rain module was the last module i included.
    So when the HC2 started, it read all the values before getting stuck at the last for the rain module. Just my guess.
    Put batteries back in, started HC2, everything OK.
    @Julegeita, My netatmo stops 3 or 4 months ago, never tought to a battery issue,i'll try tomorrow, if it works your are the best ;)
    I've tried nearly everything and even more  and never thought that i could be cause by a module not working anymore. I remove from the netatmo configuration the broken module and it starts working again !
    @Julegeita a real big thank to you !!!!
    Thank you :) Glad i could help!
    I have access to my friends Netatmo account. This means that my HC2 retreives both me and my friends data. In my case my friend had removed the batteries from his rain-meter. This made my HC2 fail. You saved my day. Thanks a lot.
    Stefan
