[Jeedom] How to program the KeyFob with menu
Good day all,
I am new with Fibaro and domotic. Last week I setup a Jeedom controller and it work fine with a Heat Controller, a light and door sensor.
I ordered a
devise and I success setup the round key to switch on/off the light. However, I have difficultly to understand how to program for a little bit more complex application. I pain to find help with the documentation, as well.
I would appreciate of you could give some tips and hints, a tutorial to better understand or if you could help to reach my goal. (I have a jeedom Z-wave controller)
The idea is to setup "a menu" with the round key and the square keys.
When I pressed once the square key:
I would like to increase or decrease the heat with the + and - key
After 5 sec, the + and - key are inactive
When I pressed once the round key:
I would like to increase or decrease the light of my room with the + and - key
When I pressed once the cross key:
my flat change to the "bye bye" mode (out the flat)
(Heat=> 5°C, lights OFF)
When I pressed once the triangle key
my flat goes to "Welcome" mode
(heat=> 21°C)
For now, my main interest, is how to setup the round and square key, to "say" to the + and - keys, on with devise (heat controller or light) they have to make an action.
I would like to avoid pressing to keys, as for example, the round and the -, to decrease the light. I guess it would be not possible, as the round and - keys, are to go to the KeyFob menu.
Many many many thnak for your help and suggestion.
I wish you a nice day.
Cheers
Edited by pierrot10
Adding tags
Link to post
  • 4 weeks later...
