jk_34 0 Share Posted December 19, 2019 (edited) Hey! I just recently bought FIBARO Home Center 2 and some smart z-wave products. Still have a lot to learn! I've created 2 easy scenes: 1) when motion sensor detects motion then my kitchen's lamp goes ON; 2) when it does not detect motion for 30 sec then the lamp goes OFF. It works fine, but my question is how can I make this happening ONLY between 5.00-6.00? Edited December 19, 2019 by jk_34 Quote Link to post Share on other sites
0 xbolten 0 Share Posted December 22, 2019 May I counter with another question... Why don't you do it with the LUX value from the motion sensor? Some years ago, I had the same question to myself and after I fixed it, I have noticed that a fixed time is not very smart. Because I need light in the dark isn't it? ... local scene = 15 -- ID of the Scene local motion = 224 -- ID motion sensor local switch = 249 -- ID Relay Switches local lux = 226 -- ID Lux sensor ... if (tonumber(fibaro:getValue(motion, "value")) > 0 ) and ( tonumber(fibaro:getValue(lux, "value")) < 5 ) and (tonumber(fibaro:getValue(switch, "value"))) < 1 then... regards Simon Quote Link to post Share on other sites
0 Stiven 25 Share Posted December 22, 2019 You can make another scene that starts that scene at 5 and terminates it at 6. (This scene needs the option to autostart when HC2 starts) Quote Link to post Share on other sites
0 jk_34 0 Author Share Posted December 23, 2019 Hey, Thank you for your answers! Simon - I tried that, but it does not work for me. I use the same lamp for two things: In the morning I want it to be motion trigged, but in the evening my wife wants to keep it on all the time between 15.00-22.00, so LUX value is a great idea, but not in my case. Stiven - that will work! What do you mean by "This scene needs the option to autostart when HC2 starts" ? Quote Link to post Share on other sites
0 cag014 432 Share Posted December 23, 2019 (edited) Did you do it in Lua or block scene? Please try to use All-in-One Scene Very easy to implement exactly what you need.... Edited December 23, 2019 by cag014 Quote Link to post Share on other sites
0 Stiven 25 Share Posted December 23, 2019 8 hours ago, jk_34 said: Hey, Thank you for your answers! Simon - I tried that, but it does not work for me. I use the same lamp for two things: In the morning I want it to be motion trigged, but in the evening my wife wants to keep it on all the time between 15.00-22.00, so LUX value is a great idea, but not in my case. Stiven - that will work! What do you mean by "This scene needs the option to autostart when HC2 starts" ? When you create a new scene, at the bottom where there are the options such: Scene is hidden Scene auto-starts when HC2 starts Do no stop when alarm is on. The second one should be ticked so even if the hc2 restarts, the scene runs automatically. Quote Link to post Share on other sites
0 jk_34 0 Author Share Posted December 25, 2019 Hey, Stiven - Thank you! cag014 - I only create scenes using "magic scenes" or "graphic blocks". This time is was blocks. I do not know how to create scenes using LUA yet. Your All-in-One Scene looks interesting. Any recommendations regarding good place where I can start learning about creating LUA scenes? Quote Link to post Share on other sites
0 cag014 432 Share Posted December 25, 2019 (edited) You can start here https://manuals.fibaro.com/knowledge-base-browse/getting-started-with-lua/ By the way meanwhile to implement what you need just add line below to jM{} table in All-in-One Scene Assuming your sensor ID=700 and light ID=800 (change IDs according to your setup) {0,"700",{state="value=true", timeSlot="05:00~06:00", trueAct={"800","turnOn",""}, falseAct={"800","turnOff","30"} }}, As I said, few seconds and you done. no LUA knowledge required... Edited December 25, 2019 by cag014 1 Quote Link to post Share on other sites
jk_34 0
Hey!
Edited by jk_34Link to post
7 answers to this question
