generalmark 0
I am new to the Fibaro product line. I have a smartthings hub and am trying to use one of the FGBS222 inputs to activate a z-wave command which I could then
program an automation to trigger a chime always, and turn on lights between sunset and sunrise. The driveway sensor is connected to a Security panel zone, which can provide a dry closure
or an active low output. The FGBS222 is powered from the control panels 12vdc supply.
I can add the Fibaro module to smartthings as a door /window sensor and it shows contact status open. (I didn't see any option to add it as a UBS device)
However, when I apply or remove a ground for an extended period to in1 or in 2 the status doesn't change. If I cause a very quick ground, then it will toggle open & closed respectively. Any help would be greatly appreciated.
Edited by generalmarkgained more information since post
