Homekit support via Homebridge
Guest mbnn
For those looking for Homekit support with HC3, Ilcato has released the Fibaro Homebridge plugin for the HC3:
If you have a Synology, go checkout this handy package:
Includes GUI for Homebridge, installs on your Synology NAS and you can easily add plugins like the Fibaro HC3 ?
It's ok now, I have create 'variable' in Fibaro - 'Général' - 'variable'
Only, there isn't status feedback, the button in homekit remains on (or off) when the barrier has finished its course.... ?
is it me or there is no Quick Apps support in current v1.1.7??
I have a simple Quick App with three buttons, but it's not visible in HomeApp.
 @naboo, today the version is "1.1.14" from april 6th ;-)
For my last question I find a little solution.
Now in homekit i have 2 buttons, one for opening the gate and one for closing. When I press the "Open" button, it lights up. When I press the "Close" button, it lights up. When the gate finishes closing, the "Open" and "Close" buttons switch to off mode. So for the next action I no longer have to hesitate if the button is on or off. All this is possible thanks to "scenes" and the use of variable in Fibaro
Is it possible to communicate HC3 global variables to HOOBS and use it in automation?
Hi all, getting this error with HomeBridge and Fibaro;
Running the latest and greatest, anyone seen this before?
W dniu 5.03.2021 o 12:54, JLT007 napisał:
I had a solution that I share with you
I asked the question to the developer, he said not to put anything in "URL" but only in "Host".
And now it works.
Why ? I don't know...
Now I need to create variables in HC3, but I am looking for how to assign these variables to devices ... like the portal command ...
An idea ?
Hey! I'm struggling with the Hoobs setup as well. The readme file says "Remember to configure the plugin in config.json in your home directory inside the .directory." any hints on how to set it up? In your case after using host instead of url have you done anything with the certificate?
