mariokil 11
I'm trying to configure ZXT-600 with my HC3 but I have some challenges/bugs.
*Disclaimer - at this moment I'dont want to use any specific AC. I'm doing this as a "dry run" before final installation
1. HC3 without any problem recognize ZXT-600 "devices". ZXT-600 is wotking wit USB power adaptor.
2. I'm trying to configure ZXT-600 based on manual (
) . At the beginning I added two parameters:- 27 [Set IR Code number from built-in code library 27 (0x1B)] - I choose one of the Mitsubishi
- 30 [Set Auto Report Condition Trigger By Room Temperature change 30 (0x1E)] - I choose value what menas based on manual "Auto report if room temperature is different from last report. 1(0x01) = 1°F (0.5°C)"
ZXT-600 has been assigned to room Kuchnia/Kitchen (details on below print screen)
/monthly_2020_03/4.JPG.48c09a6e084a124e088c83b6009af849.JPG" />I used iOS Fibaro application for HC3 and it looks that HC3/ZXT-600 doesn't work ijn proper way.
1. Even when I'm using parameter "Auto report if room temperature is different from last report. 1(0x01) = 1°F (0.5°C)" temperature doesn't change. Mobile application and Fibaro HC3 dashboard present one value (updated during power adaptor has been detached/attached)
Is it a bug, malfunction or my lack of knowledge how to configure devices ?
2. I assume that should be possible send IR commnad (on, off, cooling, heating ...) from mobile application->HC3->ZXT-600 to air condition IR receiver. Maybe I'm wrong or I miss something. Unfortunatelly I haven't or I can't see any places in mobile/web applications where I could be do this
Please let me know about your thoughts/experience.
Thank you
23 answers to this question
