Anyone integrated tibber on HC3 yet? I cant write LUA so need help
Build the Quickapp
but now Tibber doesn’t responses with the tomorrow values anymore:
The tomorrow response is empty []
Strange, without the tomorrow values it aint gonna work. Doesn’t work in the
 either.
Anyone else also having this issue?
Edited by SmartHomeEddy
Happy you are working on this.
Looking forward to test it my self.
Don’t have other Tibber lua code in my system then this hour cost, so can’t test with my token.
But tomorrow prices are published around/after 13.00 each day. Did you test before that time and that could be the case?
Tested in developer now, and seems to be working now if there where some issues.
Edited by dorten75
Oh, didn’t know that. I think that is the case.
I need the tomorrow values for example in the percentage child devices +1 to +5 hours at least around 19 hour at the evening.
?? Should be enough time then for planning the next hours after midnight.
So in the QA above the 2+ hour shows a reduction of 1,18% in price?
I have to look at that code, haven't debugged it because of the missing tomorrow values in this routine.
It is now: (current price - price +1 hour) / current price * 100
For example if current price = 0.7 and price +1 hour = 0.6 (cheaper) then:
(0.7-0.6) / 0.7 * 100 = 14.29%
And if for example if current price = 0.7 and price +2 hour = 0.8 (more expensive) then:
(0.7-0.8) / 0.7 *100 = -14.28%
Is that what you expect, what it should be?
Yea, that should give the correct %
Just wanted to confirm that I understood the setup.
So if the next hour price is cheaper, the percentage is positive. And if the next hour price is more expensive, the percentage is negative.
Sorry, I was only looking at the math and overlooked that part ?
In my head it is correct thinking decrease/increase. So when the price is cheaper it is decreasing and negative. When price is more expensive it is increasing, so positive.
I see that both ways can be argumented, so as long as the user know the setup it will be good.
If there maybe is room for small red/green arrows showing the direction it would make no doubt.
I will turn it around.
For the minimum and maximum price, I now compare to all available values today and tomorrow. In the morning till 13:00 there are less values available (without the tomorrow results) and from 13:00 there are 24 more results available. So the minimum and maximum price changes depending on the amount of available values. That sounds a bit strange. Maybe it is better to get the minimum and maximum prices from the next 12 hours.
I agree - looking forward 12 hours should be good enough and makes sense.
The new Tibber Monitor quickapp is available for download and testing. Enjoy and hope to get some feedback.
Hi I see that some in here have tibber pulse, Fibaro recommends Qubino 3 phase smart meter z-wave. It is 100% compatible with Fibaro HC3 and shows all values in real time. I have made a video on how to limit power consumption to 5 kW. The video is in Norwegian.
On 11/24/2021 at 6:38 PM, TrygveD said:
The LUA language for HC3 is different from HC2. Does anyone have a code for getting information from Tibber Pulse to my Fibaro HC3?
The quickapp for Tibber Live (Pulse) is available.
