I replaced HC2 with HC3 recently. I can´t add new  devices and when i trying reboot then it freezes.
What could be wrong?
Hello
I also had this problem.
It was because of the first firmwhare it was true.
After I switched to the latest (5.021.38), the problem was also fixed.
Do the following:
1. Reset the HC3
2. Switch on and wait until the controller is online again
3. Firmwhare update
Then the error should be corrected.
Greetings from Germany / Sauerland
    Thank you for your answer FBerges.
    Problem is when i try to reset the HC3 it also freezes.
    Should I  return it? Maybe its´s something wrong with the HC3
    @SebastianM
    Have you tried the recovery function? (Instalation manual Side 11)
    Then to factory settings etc.
    If all of this doesn't work, I would talk to the seller and send it back.
    Sorry, I can't think of any more.
    F.B.
