For watering our plants I develop a Virtual Device with HC2 using control buttons to open a valve during 15, 30, 45 and 60sec.
I also had a emergency STOP button to close the valve immediately within the same VD.
When I reproduce the same with HC3, it is not possible to call the STOP button (interrupt) untill the watering in progress is not completed.
Any help?
(and not entionning those buttons are not displayed on the portable Android/IOS...)
Could you post QA code?
    Here is the QA code for this application.
    The problem I am facing is that when one of the button call (15, 30, 45 60sec) is executed, action on the STOP button is not taken into account untill the elapsed time is reached, while I would like to interrupt the excuted code in progress.
    Code is documented in French, but so simple that I am sure you will understand!
    Action is in this example is 539 and corresponds to a Fibaro switch activating a valve.
    Thank you if your can help.
    Also the button cretaed in this example are not shown on the tile in the android/ipad application...
    You can't do a "while ... end" loop - that will block all other button calls in the QA. You need to restructure the loop with setTimeout to give time to other buttons.
    In other words, you have to learn to loop with setTimeout...
    (bit unsure how you want to update the button4_1 text...)
    You may want to call QuickApp:cancelTimer() to stop timer if any other button is pressed while the timer is running
    Long discussion on this topic in another thread
    Here is an example
    Thank you so much for your time. I will have a look at this function and hopefully make it work.
    all is fully functional by now, thank you again.
    now just waiting for Fibaro to fix the problem with mobile apps and have the button just created to be displayed :-(
