hello
I'm ready for teamviewer sesion
hi, it's the first time i try to integrate LG & broadlink with lua,
10der, can you pls suggest me a program to open the "universal file" you have created? (.fqa)
i want to make a try,
another question, can you suggest me something to beghin to study?
thank you very much!!!!
    now support RM4
    * discover button just print all devices in your network
    [08.11.2020] [21:08:30] [DEBUG] [QUICKAPP1948]: { ["blMac"] = c8:f7:42:f6:07:18,["blIp"] = 192.168.1.68,["blDeviceType"] = 10039,}
    [08.11.2020] [21:08:30] [DEBUG] [QUICKAPP1948]: { ["blMac"] = 78:0f:77:63:c4:0b,["blIp"] = 192.168.1.75,["blDeviceType"] = 10141,}
    [08.11.2020] [21:08:30] [DEBUG] [QUICKAPP1948]: { ["blMac"] = 34:ea:34:e3:d9:2e,["blIp"] = 192.168.1.39,["blDeviceType"] = 10039,}
    [08.11.2020] [21:08:30] [DEBUG] [QUICKAPP1948]: { ["blMac"] = c8:f7:42:40:99:c3,["blIp"] = 192.168.1.14,["blDeviceType"] = 10039,}
    [08.11.2020] [21:08:30] [DEBUG] [QUICKAPP1948]: { ["blMac"] = c8:f7:42:83:3b:83,["blIp"] = 192.168.1.20,["blDeviceType"] = 10039,}
    [08.11.2020] [21:08:30] [DEBUG] [QUICKAPP1948]: { ["blMac"] = 24:df:a7:34:89:e2,["blIp"] = 192.168.1.51,["blDeviceType"] = 20954,}
    * getSensors method for RM4 can print the current temperature and humidity
    [08.11.2020] [21:54:45] [DEBUG] [QUICKAPP1948]: onAction: {"actionName":"getSensors","args":["192.168.1.51"],"deviceId":1948}
    [08.11.2020] [21:54:46] [DEBUG] [QUICKAPP1948]: 25.5 64.7
    * for using RM4 you should provide additional param
    ex
    all RM
    local irRfCode =
     "26006800C0FA1272137214711471132F1471142E1471132F132F1131132F1372142D1471123014711174142E1471117413721372132F132F132F1372132F132E142E12301471142E1471142E1471132F1372142E132F1174132F1372132F1371142F1371147114F513000D05"
     fibaro.call(1948"sendIRCommand""192.168.1.39", irRfCode)
    for RM4
     local irRfCode =
     fibaro.call(1948"sendIRCommand""192.168.1.51", irRfCode, 0x51da)
    • 10der changed the title to HC3 : Broadlink HUB (with support RM4)
    • 1 month later...
    On 6/3/2020 at 1:47 PM, Szakos said:
    Dear 10der,
    Can you please give more details how to made it ?
    I have RM4 mini and I need to use with my HC2.
    Thank you for your help.
    did you manage to use broalink with an hc2? I am thinking of buying 1 broadlink 4 to use with fibaro and home assistant.
    did
    • 4 weeks later...
    Hello 10der,
    a German Fibaro fan advised me to write to you about my project. I have a Neff cooker hood that is controlled by a 433.92 Mhz remote. With the help of a RM4 pro I managed to learn the radio codes and control it successfully via the RM4 pro. I have also already created scenes in the Broadlink app. Control via Alexa is therefore possible.
    /monthly_2021_01/grafik.png.bfaf26557681089d942e0691ab499922.png" />
    I follow with high interest this blog. Now I would like to access these functions of the cooker hood via my HC3. But, I have no idea how to proceed now. I have already installed your latest version of QuickApp Broadlink Hub. My hub is also found.
    How can I call the individual buttons / functions / scenes?
    Many thanks for your help.
    @Frasdorferhi!
    thank you for using my QA but unfortunately my QA works with IR and i never test this QA with Broadlink RM4 pro and RF data.
    I have old  RM4 pro device but also never to test and use RF data ... cuz do not have any devices with RF.
    Is there any way to query the codes or use the trial and error method? Can I somehow support so that we find out. That could certainly help others. Any idea how to proceed further.
    yes you can grab codes by itself.
    here is article how (for home assistant)
    so. you should get string for each button.
    than youe should contribute QA code and add method for sending RF string to device.
    • 1 month later...
    On 11/9/2020 at 4:01 AM, 10der said:
    now support RM4
    ex
    all RM
    local irRfCode =
    for RM4
     local irRfCode =
    Good Day @10der. I have gone through the all forum post about broadlink QA and thanks for the QA! May I clarify something about how to use the QA?  First, is whether to connect broadlink RM4 directly to HC3? Besides that, how to do the learning and copy the IR/RF code specifically for broadlink's IR format? Thanks!
    On 11/1/2020 at 4:50 AM, 10der said:
    Tak,
    1) install
     (HC3 only)
    2) install QA for toshiba
    change IP address for your BL device
    192.168.1.39 - you IP address broadLink RM4
    Hi @10der, I managed to get the IR code from home assistant's Broadlink integration. Then insert the IR command based on the Toshiba fqa.  I revised the code based on RM4 Pro and it still unable to control the AC device.   May I know if the code is correctly edited??  Thanks!
    • 2 months later...
    Hi All
    I receive the following message
    [DEBUG] [QUICKAPP649]: onInit[30.04.2021] [00:48:10] [TRACE] [QUICKAPP649]: UIEvent: {"values":[],"eventType":"onReleased","deviceId":649,"elementName":"Discover"}[30.04.2021] [00:48:11] [DEBUG] [QUICKAPP649]: ./include/manager.lua:166: attempt to index a nil value (upvalue 'myIP')[30.04.2021] [00:48:11] [ERROR] [QUICKAPP649]: QuickApp crashed[30.04.2021] [00:48:11] [ERROR] [QUICKAPP649]: Unknown error occurred: handleJsonRpc
    Does any one know what i do wrong
    • 3 weeks later...
    Thank you for working on the Broadlink_hub (v7).fqa - I installed it for my RM4 Pro
    I made the Discover, and it looked good i think...
    [16.05.2021] [15:00:03] [TRACE] [QUICKAPP1226]: UIEvent: {"values":[],"deviceId":1226,"elementName":"Discover","eventType":"onReleased"}
    [16.05.2021] [15:00:09] [DEBUG] [QUICKAPP1226]: true
    [16.05.2021] [15:00:09] [DEBUG] [QUICKAPP1226]: { ["blDeviceType"] = 24994,["blIp"] = 192.168.201.219,["blMac"] = a0:43:b0:18:b2:ea,}
    Trying to send
     local irRfCode = "26006800C0FA1272137214711471132F1471142E1471132F132F1131132F1372142D1471123014711174142E1471117413721372132F132F132F1372132F132E142E12301471142E1471142E1471132F1372142E132F1174132F1372132F1371142F1371147114F513000D05"
     fibaro.call(qaHub, "sendIRCommand", broadLink, irRfCode, 0x51da)
    is getting - AUTH false 65535 nil -
    [16.05.2021] [14:48:05] [DEBUG] [QUICKAPP1226]: onAction: {"actionName":"sendIRCommand","args":["192.168.201.219","26006800C0FA1272137214711471132F1471142E1471132F132F1131132F1372142D1471123014711174142E1471117413721372132F132F132F1372132F132E142E12301471142E1471142E1471132F1372142E132F1174132F1372132F1371142F1371147114F513000D05",20954],"deviceId":1226}
    [16.05.2021] [14:48:05] [DEBUG] [QUICKAPP1226]: AUTH false 65535 nil
    [16.05.2021] [14:48:05] [ERROR] [QUICKAPP1226]: Can`t auth device 192.168.201.219
    anyone one know how to fix this ?
    Trying to send
    i found out
    On 11/8/2020 at 9:01 PM, 10der said:
    now support RM4
    ex
    all RM
    local irRfCode =
    for RM4
     local irRfCode =
    Below is a description for this QA for controlling the Broadlink RM4 Pro QA.
    first download 10der Broadlink RM4 Pro QA - version 7,
    Install this QA - i Updated the test file from Darren_Teh
    learn the Ir/Rf Codes - with
    (former versions will NOT WORK with RM4 Pro)
    Or Use Home Assistant, Developer tools, Services to learn the codes. My services looked like this
    service: remote.learn_command data: device: GardinChannel_01 command: opper command_type: rf target: device_id: 476849a16e4e75fba490e7de8f7481b1 entity_id: remote.wi_fi_universal_remote_remote
    and look in the file config/.storage/broadlink_remote_a043b018b2ea_codes for the scanned/learned Data
    I got it working with 433Mhz RF blinds from Jysk.dk called Huglo.
    the Broadlink RM4 Pro QA is made by 10der and can be dowbloaded from here
    Please be ware this QA searches for the Broadlink RM4 Pro QA by NAME, and the 10der Broadlink QA should be renamed to "Broadlink RM4 Pro" to work
    In the Broadlink mobile APP. you need to go into the app under the Broadlink device and deselect "Lock device". if not done, the Broadlink RM4 Pro QA will fail authentication.
    the QA can be downloaded from here
    it need to be called like this, also if you are using RF
    • 2 months later...
    I have made 2 videos on how to add the Broadlink RM Pro to HC3 and how to take the IR codes from the Broadlink device without using Home Assistant or RM Bridge (Usings Android Phone) - DM me if you want a link to the videos
    • 4 weeks later...
    @Rodolfo you need a bridge for HC2 using RM Bridge software on an Android device.
    • 3 weeks later...
    With help from @10der I have made a video tutorial on the RM Pro and RM4 Integration to HC3
    Edited by Phenix
    • Thanks 2
    @Phenix Thank you for making a tutorial video. Appreciate it.
    Hopefully it worked for you
